Old 04-13-14, 07:42 PM   #1
greif
a van down by the river
Default water softener
Does anyone have one of the salt free water dofteners? If so how do you like it
Thanks
Gary R
Old 04-13-14, 08:42 PM   #2
Does a potassium chloride system count?
Old 04-13-14, 09:34 PM   #3
greif
Sorry, should have been more clear. Nope. There are systems that don't regenerate by back washing. Instead of exchanging salt or potassium ions for the calcium or mag in the water they convert the cl and mag so it stay in suspension and won't build up on you faucets etc.
I am just looking for people who have used both systems and what they liked better
My salt system is almost 13 years old and I can tell it's going and needs the medium replaced so thought I would look into other stuff out there
Thanks
Gary R
Old 05-15-14, 03:29 PM   #4
What did you end up finding out?
Old 05-15-14, 05:10 PM   #5
greif
Never found anyone that has one to see first hand experience, but on other forums I did find a lot of jerky type people that think they know it all
I did find a lot of info on regular water softeners and the best hardware to buy and that they are easy to set up so will order a really good one online and install myself
Thanks
Gary R
Old 05-15-14, 06:04 PM   #6
philb
My daughter unhooked her water softener after she had a scale blaster installed.
"So.... we installed the water softener I told you about. We turned off
our salt water softener and the scale blaster is working really well.
The plumber said he was skeptical too, but that it really works and it's
the same technology that's used to clear arteries, etc."
ScaleBlaster | The Eco-friendly Solution to Hard Water | Water Softener Alternative
Old 08-05-15, 01:30 PM   #7
Scaleblaster SB 175 | eBay
I've been looking at this type of gizmo.. Saw this:
https://youtu.be/DMADNzsM9xQ
I've also seen DIY kits under "Electronic Water Descaler Decalcifier Conditioner "
on Ebay..
Electronic Water Descaler Decalcifier Limescale Remover DIY | eBay
I wonder if anyone here has been using one of these DeScaler gizmos.?.
Old 08-05-15, 01:52 PM   #8
Sounds quite interesting. I wonder how much power it uses.
Old 08-05-15, 02:22 PM   #9
vskid3
vskid3's Avatar
The SB-175 says <15w on the data sheet.
vskid3 is offline   Reply With Quote
The Following User Says Thank You to vskid3 For This Useful Post:
Daox (08-05-15)
Old 08-05-15, 02:58 PM   #10
Thanks, I missed that.
