Old 11-11-09, 08:40 AM   #11
The crankcase heater is probably triac-controlled so even that won't be a linear load.
Old 11-11-09, 02:31 PM   #12
It might even be using DC with PWM.. Or a relay.
The Elite unit was only £47.74 GBP. It will be winging it's way across the Atlantic soon..
Old 11-11-09, 08:49 PM   #13
I think it would use a triac because it's the cheapest way to get variable power.
Old 11-11-09, 10:01 PM   #14
I haven't a clue. It could be running full 230VAC and using the Compressor thermistor to signal shut off.
I would really like to see the schematics of those two PCBs..
Old 11-12-09, 08:31 AM   #15
At that low power level, a triac is actually cheaper than a relay.
Old 11-12-09, 12:10 PM   #16
That could be the case. I've noticed the similar 18,000 BTU Sanyo does
not even have a Crankcase heating element..
So, maybe it's only 20 or 30 watts being used..?.
