11-09-13, 05:41 PM | #1 |
Inexpensive Backdraft Damper that actually works
I have tried the store bought metal butterfly backdraft dampers with the 4 hot air collectors I have plugged into my house.
None of them were stopping the cold air backdrafts that happen when the sun goes away. After doing some digging, I ended up finding a different Mfg. backdraft damper on the web that I liked so decided to copy their design and see if I could get good results. After some trial and error with different materials I finally nailed the problem. I made a pdf file showing the build which is here for anyone interested. A minimum of materials are needed to put these together..
Pat from Warwick, RI Please Note: Comments and/or suggestions I make here at the forums on 'your' projects as well as my own have all been carefully and scientifically calculated by 'the seat of my pants' To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by solarhotairpanels; 11-09-13 at 05:50 PM.. Reason: adding pictures |
The Following 4 Users Say Thank You to solarhotairpanels For This Useful Post: |
Tags |
backdraft damper diy |
