Old 02-07-18, 12:20 PM   #11
ThMihov
Good evening everyone
Ron342,i like the idea for detecting the blocked air flow,but for now,I'll keep it simple and use a temperature sensor,because the forecast about the next week is talking about temperature drops and rain/snow fall,and i want to make it work until then and log some data,but for future improvement it's really a good idea
Great exchanger,i like it very much.I was thinking to use two 6mm pipes in parallel in 20mm PE pipe.In that way I'll have big heating area with small amount of water,which means greater output water temp and faster heating,but before i begin to experiment with the heat exchanger,i want to make some measurements on this setup.If you have some free time,i'd like to hear more about your exchanger,setup and results
As for the hardware/software-I'll try to explain the things in simple and at the same time detailed way.The setup is a nightmare-Arduino board with a bunch of wires around it,without any labels,but...
In an hour I'll try to explain the idea for the control
ThMihov is offline   Reply With Quote
