#81 |
![]() Nice, tight job of the basement, it must be somewhat sound proof as well,which is a bonus if you have children or loud friends over perhaps with music..Nice job.
#82 | |
![]() Quote:
I don't any way to measure power consumption of only the heat pump, but my total electric usage hasn't been over $150 for any month, including a resistance water heater and lots of computer & electronic equipment that's always running. You should try keeping them running non-stop and see what your consumption is. Running it intermittently might cause excessive defrost cycles which cause a huge reduction in efficiency. Also, a heat pump efficiency is max when the delta-T is minimal. So, the savings of permitting heat loss at mid-day and night is countered by a loss of efficiency when it is heating with greater delta-T, especially if more defrosting occurs. We don't know the exact numbers involved so I could be very right or very wrong. Also if outdoor temps are close to the manual-J design temps, and your heat pump capacity is close to your home's design heat loss, then leaving them run 24x7 would have them just meet your needs. Turning them on & off at these temps would push them past their capacity limits, as they can only put out so much btu/hr. Hope you get it worked out! |
#83 |
![]() Any updates on the house?
#84 | ||
You Ain't Me
![]() No. Nothing really exciting happening on the energy efficiency front here. I have been still doing some work in the attic. I'm installing whole house audio and three rooms upstairs are getting ceiling speakers. Obviously these are giant holes for energy and moisture to move through so I've made drywall boxes to cover them and air sealed the bejesus out of them. I'll take a picture of one soon. I had an unfortunate incident with the U.S. Dept. of Ed. mistakenly hijacking $8,000 from me so just about everything is on hold until they get of their keisters and reimburse me, which they said could be 60 days. As soon as that happens I'll be finishing the attic. I'm going to have the 2 part guys where I work seal the eve top plates and propa vents and then I'm going to blow about 18" more cellulose on top of my existing 7".
My project: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Chipping away on a daily basis. Quote:
#85 |
![]() Sounds like a good plan. Keep us updated.
#86 | |
![]() Quote:
#87 | |||
You Ain't Me
![]() Quote:
My electric company has a DER rebate program. I'm going to see if I can borrow money from.... well, someone.... to finish the top floor this summer with the hopes that the National Grid DER incentive will reimburse me for most of it. There are 0% loans one can take to do certain kinds of work on their houses in New England. It would be great if it were easier for those of lower incomes to get these loans. The payment would be less than most utility bills in the winter and the ROI would probably only be a decade or so! A great quote I saw on GBA recently (I forget who said it. One of the long time green builders out here) "In 20 years your $100,000 kitchen looks 20 years old. In 20 years your super insulation looks better and better". But! For the faint of heart, I have know how and I have gumption!
The Following User Says Thank You to S-F For This Useful Post: | AC_Hacker (04-18-13) |
#88 |
![]() "Residential Building Envelope Whole House Air Leakage Installer"
Careful, sounds like you are installing whole house air leakage into residential building envelopes. |
#89 | |
![]() Quote:
What is the price of electricity in your area, and what is the price of gas in your area? Did you try the BuildItSolar Fuel Calculator? You can plug in your local values... I'd be very interested to know your results. Best, -AC
