10-09-12, 07:37 AM | #1 |
hello
I'm looking for a way to heat my garage/workshop, and came across your website so I though I would drop in.
10-09-12, 07:49 AM | #2 |
Welcome to the site steeltoe.
There are many great ways to heat a garage depending on what you have available to you as a heat source. Do you use your garage as a work shop or something, or do you just want to keep it warmer in there?
10-09-12, 08:01 AM | #3 |
I use it for everything except storing my cars, (the intended use). I have a lot of woodworking tools, which I use mainly for home repair.
10-09-12, 08:36 AM | #4 |
I would highly recommend using solar hot air panels. They're inexpensive to make, operate automatically and require no fuel. They're what I want to use when I eventually insulate my garage (used for working on cars, rarely storing as well haha). If you need a more on demand type heat I'd recommend a wood stove since you do wood working and could burn scraps as well as brush from the yard (or if you've got woods around the house that is all fuel).
10-09-12, 12:28 PM | #5 |
Hi steeltoe , name sounds familiar
I like your new project, free heat is the heat of the future, No taxes no fees, after construction costs zip. My future has a system in it.. |
