Old 10-06-12, 06:26 PM   #1
Default Safety Improved
My wife has wanted porch rails every since we got the new porch a few years ago (maybe 5 or 6 years?).
Home Depot had the DIY stuff (that looks almost professionally installed), but it was way over-priced.
She wanted a safer porch (with rails) and wasn't very concerned about price.
Now that we're getting really old and brittle, (and more ice is on the way) it was past time to get it done.
So, I ordered the EZ HandRail stuff and saved a few bucks paying for labor.
Here's the pictures, in reverse order.
Rail pictures by Xringer - Photobucket
Old 10-07-12, 07:49 AM   #2
Looks really nice IMO. How sturdy is that stuff?
Old 10-07-12, 08:48 AM   #3
It feels very solid. The railing sections are as good as I've seen on the balconies at large hotels.
You can read the dimensions (thickness etc) here. http://www.hdezhandrail.com/documents/Engineering.pdf
The only thing that I didn't like was the smallish size of the self-tapping screws used
to secure the brackets to posts. I would have preferred beefier hardware at those points.
But, I have no doubt these will hold up to normal use for many years after I'm long gone..
Which is a lot more than I can say about the wrought iron rails that most folks around here have installed.
Those are actually steel in many cases and not only rust out at the bases,
but the whole rail will bend over if someone heavy falls on it.
Those need to be well attached to the house. Not just a 3" lag bolt.
Old 10-07-12, 10:56 AM   #4
Exalta-STA
Looks good!
Exalta-STA is offline   Reply With Quote
Old 10-07-12, 11:51 AM   #5
I like the looks too. But, my wife wants me to cut the top off the middle posts! Says they are too tall..
Having a little hand rail is nice to keep you from falling, but if you do fall, most folks can't hang on to a handrail, while descending stairs.
Due to the angle of force applied to your hand, first, your pinky gives up, then your ring finger.
The railing is ripped out of your hand, starting with the weakest finger.
BUT, if you start to fall, and grab a big strong vertical post, your grip will be much better.
And, you should have a better chance of stopping your fall.. (IMHO)..
