Old 03-12-14, 08:57 PM   #31
nokiasixteth
I think i need to foller that thread for under a hundred bucks.
I just found one for 250 bucks needs what he said is EEV valve or a temp sensor.
Or a brand new one a guy has that bought a on demand water heater instead. for 600
Yea it has a ethernet port.
Heres what i found.
GE also integrated an ethernet port on the control panel. This will enable the unit to connect to GE’s Nucleus Home Manager System, integrating with your home network. Connecting to this system will allow your GeoSpring water heater to send alerts if the device needs maintenance. You can also change the water temperature from an app, and track energy consumption on your computer.
Old 03-21-14, 06:09 PM   #32
Unhappy
I've made up my mind: I am going to hunt down parts and build one of these. I was just asked to swap out a 40 gallon electric water heater because one of the pipe threads has a leak at the plastic pex fitting! Reasoning is this: it's almost 10 years old, so this must be a sign of things to come. No joke.
With a donated water heater and a couple of window units sitting in line, I believe I can tackle one of these for under $100.
Well, so much for that idea. The owner went and priced replacement water heaters. After that, he changed his tune. Need less to say, I'm not going to be getting that one. It is well worth repairing. He said a 40 gallon, glass-tank replacement was in the range of like 600 bucks.
I'm just on the edge of my seat, waiting for that call...
Old 03-21-14, 09:48 PM   #33
Any reason you couldn't convert your existing water heater or build a unit that works with it?
Old 03-22-14, 03:29 AM   #34
1. It's natural gas
2. I rent
Old 03-22-14, 08:20 AM   #35
If you make a unit similar to mine, no modifications to the tank and minimal plumbing work are needed. It just piggybacks onto an existing sink or washer hookup.
Old 03-22-14, 12:40 PM   #36
Details? Thread reference?
I have questions, but they may be answered elsewhere already.
I could possibly do this. I have an amped up dehumidifier sitting around already. I built it as a proof of concept that I could run it backwards to provide heat.
Somewhat clothed:
Naked side shot
1/2 ton txv closeup
It did its job well for its size. The evaporator no longer froze every 1/2 hour and it put out lots more heat. Its heart is a Rechi 5000 btu, just like in all the 5000 btu window a/c units.
Its big brother (10500 btu):
Naked view (note blue sugarcube relays to control fan speed)
It heated the house quite well, sucking in ambient (room) air, blowing cold air outdoors and warm air indoors. She said it sounded like a jet engine, so it had to be exiled...
Old 03-22-14, 02:05 PM   #37
You do it pretty much the same as the conversions often done here, but you use a heat exchanger instead of coiling tubing in a tank, then adding a pump to move the water.
