#11 |
![]() Daox,
I had a similar problem with a heat pump project. Standard pipe thread is tapered and relies on a progressive interference fit to work. There are other pipe thread systems that do not rely on tapered, progressive interference to work. Instead, they use a flat compression washer. The straight threads supply force to compress the washer. If you were crossing systems, it would feel gritty, because very small bits of thread faces were being sheared off by your struggle to make it seal. One give-away is that the thread shoulder (male and female) has a precision-machined surface. There's a good chance that the damage to the threads is not completely fatal yet. If the machined surface of the shoulder is still intact and undamaged, you may be able be successful. Of course, you need the proper straight-thread part and the proper compression washer. If the damage has been too severe, there's epoxy. Best, -AC_Hacker
#12 |
![]() Thanks for the tip AC Hacker. I'm aware of this. The unit we were working on had male NPT threads on the outside. They were definitely tapered.
The Following User Says Thank You to Daox For This Useful Post: | emilyhendrix (02-21-17) |
#13 |
![]() When you said that "half the joints leaked", what are you referring to? Your heater only has two, IN an OUT, right?
Are they leaking? Are half of all the joints you put together leaking? This is very strange. It sounds like you have been invaded by a different Physics that doesn't apply in the rest of the universe.. Maybe you should go copper at the heater, and switch to PEX ASAP. -AC
The Following User Says Thank You to AC_Hacker For This Useful Post: | emilyhendrix (02-21-17) |
#14 |
![]() Gasoila is used in the gas station business for installing underground tank fittings and more. You could likely find a petroleum equipment supplier (relatively) locally that would have it.
Hope this helps Last edited by Daox; 01-13-17 at 01:15 PM.. |
The Following User Says Thank You to gasstingy For This Useful Post: | emilyhendrix (02-21-17) |
#15 |
![]() We made a few other connections off the heater to ball valves for flushing the heater with vinegar.
In the end, we switched from the threaded fittings to compression fittings as that was another option that came with the heater. Those sealed up just fine.
#16 |
Land owner
![]() To get 3/4npt fittings to properly seal it takes 100ft.lb, I have found that most npt fittings that leak are not any where near tight enough.
The Following User Says Thank You to oil pan 4 For This Useful Post: | emilyhendrix (02-21-17) |
#17 |
![]() I use Loctite 55, its a cord with PTFE or the like on the cord, seems to keep on the thread better than PTFE tape and you can realy feel it's there when tightening up the joint.
The Following User Says Thank You to 1234enough For This Useful Post: | emilyhendrix (02-21-17) |
#18 | |
![]() Quote:
The Following User Says Thank You to rclark762 For This Useful Post: | emilyhendrix (02-21-17) |
#19 | |
![]() Quote:
Thx steve for the idea to wrap the inner threads and goop the outer. I will try that next time.
Current projects Chevy Volt battery pack conversion To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Blog that is down right now but will return To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Business where I sell solar stuff [url]https://www.bobolinksolar.com |
