#21 | |
![]() Quote:
If you go 48volt there are alot of golf carts 48volt, might be easier and cheaper to get parts, motors, chargers and so. |
#22 |
a van down by the river
![]() evdrives.com/kits_conversion.html]EV Drives Conversion
thinking about either kit 5c or 6c I want to make sure I have enough power for plowing snow as we get feet at a time and most golf carts are underpowered.
Gary R “If you want total security, go to prison. There you're fed, clothed, given medical care and so on. The only thing lacking... is freedom. ” ― Dwight D. Eisenhower |
#23 |
![]() There is a lot of stuff out there, as to whats best for you???
You got to look at everything, power, run time, cost. This is where I got my controller and foot throttle >Cloud Electric, LLC |
#24 |
![]() How does the electric conversion compare to the original tractor, in terms of reliability and cost to operate?
#25 | |
![]() Quote:
As far as cost to put it together, it's probably more than buying a good working used tractor just like it. Cost to operate, that depends on how long the batteries last, the ones I have are $100. or so each. I think if you take care of the batteries, keep them fully charged and not let them sit on a low charge you will get max life out of them. |
#26 |
![]() Hi dh1
![]() what did you use for batteries? I assume just deep cycles lead acid, and not gel or AGM but since I will be searching I need to try to guess on size to get long running time but yet balance price. So if you don't mind sharing what brand, model and AH rating.
#27 | |
![]() Quote:
there group # 27, paid about $100. each for them. |
#28 |
![]() Today I tried the Brinly 10" plow on the tractor, mounted to a sleeve hitch and also installed 1 set of 26lb. wheel weights.
Tractor seems to have enough power to pull the plow, lost traction a few times, might need some more weight or a set of AG tires, right now it has a set of loaded turf tires. Still need to do some adjusting on the setup to get the plow to work properly but the main thing is that the tractor can pull the plow. 1st gear, no problem but awful slow. 2nd gear, seems to work the best, faster than 1st. 3rd gear, the motor is really working hard, faster than 2nd but I think the limit is reached here. 4th gear, forget it, not enough power to pull. |
#29 |
![]() Wow, I'm surprised you had enough traction to put that through the earth. Very nice.
#30 |
![]() Great information shred here! I really enjoyed being here.
