12-09-12, 11:55 AM | #1 |
Romania says "cheers"
Hi everybody, as the everlastig note says, I'm "saying hello to our community in our Introductions forum."
I'm a romanian tinkerer, got 2 wells (10 m deep) and seriously reading GSHP thread, because I will learn to use my well water to heat (maybe cool too) my home. Did try HCS on automotive field (1995 E200 MB) with no obvious positive results (old sensors, smart car calculator which couldn't be tricked yet). Open minded to any reasonable economy mod. Yours, Stefan |
12-09-12, 01:50 PM | #2 | |
I take it you've read the Home Energy Saving Tips. If you want to save with your car, then check out EcoModder.com. BTW, What is HCS?
The Following User Says Thank You to Piwoslaw For This Useful Post: | Pilgrim (12-10-12) |
12-09-12, 08:10 PM | #3 |
Welcome to the site Stefan. Piwoslaw has some good suggestions.
The Following User Says Thank You to Daox For This Useful Post: | Pilgrim (12-10-12) |
12-10-12, 12:13 AM | #4 |
HCS = Hidrocarbon Cracking System. There is a dedicated (may be more) thread. You vacuum gasoline fumes / vapors through a line close to the exhaust manifold, in order to improve combustion. But, in a Fuel Injected engine, the computer must be fooled into thinking there is a rich mixture (EFIE). Mine was smarter than that
12-10-12, 06:04 AM | #5 |
Welcome aboard Pilgrim!
