Old 04-01-14, 08:33 PM   #1
buffalobillpatrick
Default GE T6603-5 CO2 sensor Arduino sketch
Code:
GE T6603-5 Safe-AirTM Plus CO2 Sensor
This sensor: +5vdc on pin 3, Gnd on pin 4,
produces an open collector +Pulse output on pin 5  (with 10K pullup resistor to +5)
The duration of this pulse indicates the CO2 in Parts per Million (with manipulation)
This sketch averages 100 samples & prints out PPM  Takes about 1.7 minutes / printout
http://www.sensorexpert.com.cn/Uploa...2843_18796.pdf
http://www.tecnosens.it/media/6970/920-6603.pdf
Arduino - PulseIn
#define sample_cnt 100
int I;
float sample_avg = 0.0;
float sample_accum = 0.0;
float sample = 0.0;
float ppm = 0.0;
int pin = 11;
unsigned long duration;
void setup()
  Serial.begin(9600); // start serial communication
  pinMode(pin, INPUT);
  delay(5000);
  Serial.println("........Hello world!.......");
void loop()
sample_accum = 0.0;                    //clear accumulator
for (I = 0; I < sample_cnt ; I++)      //loop taking samples
duration = pulseIn(pin, HIGH);        //read the pulse in microseconds
sample = (duration / 1000.0);        //convert to ms
ppm = (1.996 * sample);              //convert to ppm
sample_accum += ppm;                  //accumulate samples
sample_avg = (sample_accum / sample_cnt);  //find average
Serial.print("CO2 level = ");      // Write ppm to serial monitor
Serial.print(sample_avg);
Serial.println(" ppm");
Serial.println("..............");
