Old 05-06-14, 12:32 PM   #141
It is 86 here now heading to 91 today. I like this much better than winter.
Old 05-06-14, 03:03 PM   #142
WyrTwister
I was doubtful , too .
My guess , when I got home from work ( about 05:00 PM ) would have been in the HIGH 90's ?
Today's forecast is for a high of 97 F .
God bless
Wyr
PS Need to get off my lazy behind and ( now that it has warmed up a little ) replace my old electrical service with a new 200 amp service .
Need a better place to tie in the mini split and the new electric water heater .
Old 06-05-14, 08:24 AM   #143
evolv3
You guys did an awesome job on this! Its helping me a lot in getting prepped for my own install.
I have absolutely zero experience in working with ac/gauges/pumps/etc.....lol! But I aint skeered.
Can I ask one favor?
Can you draw a diagram of how you ended up connecting everything to do the vacuum?
Seems as though you didn't even use a manifold gauge if im understanding correctly? So you connected like this?:
MS service port -> YJ ballvalve -> YJ vacuum hose -> SVG3 micron gauge (guess there is a T here included?) -> YJ vacuum hose -> Robinaire pump
Are all the service ports standard size (1/4"?) on these things that the YJ ball valve/hoses connect correctly?
I bought a mitsu MSZ-FE12na/MUZ-fe12na
Sorry for the ignorance
Again awesome write up!
evolv3 is offline   Reply With Quote
Old 06-05-14, 09:32 AM   #144
http://ecorenovator.org/forum/geothe...nstall-11.html
Look at post 110
I was just testing my new hoses here. Add a T here with the micron gouge on the T. The ball valve would go to the MS adapter and on the MS.
That is how I did mine. Once the vacuum was where I wanted it I would shut off the ball valve then release the Freon the quickly remove the ball valve.
You might want to wait for someone that has HVAC experience to confirm this I
is the best method.
Only do this if you tested your ball valve under very low vacuum the first two ball valves I got would not work under very low vacuum.
You can test your hoses and ball valve just the way I did in this post.
Old 06-05-14, 10:07 AM   #145
WyrTwister
My mini split had a standard 1/4" fitting . I have that size hoses & gauges . And my vacuum pump uses that fitting , too .
God bless
Wyr
Old 06-05-14, 10:30 AM   #146
evolv3
Thanks guys, did the yellow jacket ball valves give you issues too?
Old 06-05-14, 10:33 AM   #147
No they are great valves but you should still test them to make sure they are working good.
Mine easily pulled down to 55 microns when I tested them.
I was not sure what ball valve you bought.
Old 06-05-14, 11:42 AM   #148
Is this the unit you bought?
https://www.goductless.com/Mitsubish...ubishi:24443:1 Ton
It looks like a very nice unit.
Old 06-05-14, 12:05 PM   #149
evolv3
Close....but i got the model right below it as i dont need the ultra low temp heating options. Its going in a server room so it will never run on heat anyway.
SORRY, i tried to post a link but i dont have enough posts yet i guess.?
Old 06-05-14, 12:06 PM   #150
evolv3
Anyway to tell if i will need the 5/16 adapter or if 1/4 will connect directly?
I looked thru the manual but cant seem to see mention.
