Old 03-06-12, 01:25 AM   #11
geoheatnz
Hi there ,
to get maximum efficency from your heatpump you need to keep your approach temp low , this is the temp difference between water out of heat exchanger (hx) and the condensing temp or high pressure converted to temp on p/t chart.
The best way to do this is have as much water flow through hx as possible and to have supply from bottom of cylinder and the return to bottom as well if possible , this also gives you a small temp difference between supply and return temps and does not effect stratification of water as much as circulating from the top down.
It is also best to have counter flow like you indicated with refrigerant flow and water , also have discharge at top and liquid out the bottom of hx.
Hope this helps some.
cheers Andy
geoheatnz is offline   Reply With Quote
Old 03-07-12, 07:56 AM   #12
I was thinking of using a differential controller to turn on the pump,
whenever the HX is warmer than the stored water in the boiler.
I don't understand why you would want to preserve stratification of the stored water.
In any event, my boiler's water jacket is not like a cylindrical tank and the turbulence
in the stored water is going to be pretty high when the pump turns on,
even if the input and output were both on the bottom of the boiler.
The recirculate water (76 gallons) is stored in the water-jacket that surrounds the fire-boxes.
The only slightly large volume area is where the copper DHW HX coil sits.
Stratification does occur, but it's easily disrupted whenever HW is used,
or if one of the circulator pumps came on (in case of a call for heat).
Since I already have a pump installed (for basement heat), which I never use,
Perhaps just tapping into the pump relay with my controller,
and diverting it's water flow to my HX will be easier (and cheaper)
than adding a third pump to the mix..?.
Using hose-type shut-offs (on Tees) and a valves to shut off the basement loop,
would allow the basement pump to feed into any kind of heating unit I wanted to install,
Using washing machine hoses.. (Insulated of course).
Old 03-08-12, 12:44 AM   #13
geoheatnz
Hi X ringer,
your boiler sure is a lot different than anything we get in NZ! Is that where your hot water is stored or does this heat your house as well ? or do you have a cylinder some where .
If you were to build something like the geyser that would be the best solution for year round hot water and hooked up to a pre heat tank where it can be most efficent , get heat given off by the boiller in winter , dehumidify basement year round.
cheers Andy
Old 03-08-12, 06:33 AM   #14
Yeah, it's the middle sized model HS Tarm, holding 76 gallons in the water-jacket.
We burn 1/2 gallon of oil every morning.
If I can successfully add heat to that 76 gallons of storage, using a small ASHP,
I might be able to turn off the oil burner during warm weather..
We only dehumidify the basement during the summer,
since it's drier down there during the winter. (and colder too).
I don't know if using a DIY geyser-clone in my cold basement would be practical during the colder months.
Just have to try it out and see if it works.
Old 03-30-12, 10:58 AM   #15
Maybe your router speed controller?
The little lathe has been repaired..
And the drill-mill is still working..
But, I have a bunch of plumbing to get done before any hobby stuff gets done..
Old 04-05-12, 12:04 AM   #16
stuart1648
heres an idea for a project:turn a window ac into a window ac/heatpump by messing around with ducts rather than valves.Ie..in the normal ac mode ducts stay same but in heatpump mode ducts reverse the airflows.
stuart1648 is offline   Reply With Quote
Old 04-05-12, 08:12 AM   #17
Default Install it backwards?
That works. Easy to do, but the results are less than spectacular.
http://i46.photobucket.com/albums/f1.../NCL/setup.jpg
http://i46.photobucket.com/albums/f1...L/outdoors.jpg
http://i46.photobucket.com/albums/f1.../NCL/90deg.jpg
The outdoor temp (being cool in winter) will keep shutting it off.
You just need to move the temp sensor on the indoor coil, to the outdoor coil (heat out).
That would trick the control into thinking it was really hot indoors and
make the motors run.
Old 04-05-12, 09:33 AM   #18
stuart1648
Default reverse the ac
That would involve moving the ac around and attendant hassles as you say;I meant leaving things be but merely redirecting airflows via low -tech ductwork ;ie..inside air is redirected out and vice versa;the temp control would just be used backwards
Old 04-05-12, 09:36 AM   #19
You really won't know until you try it.
Old 04-05-12, 10:29 AM   #20
Take a look at the locations of the coils. What you suggest would be way more trouble than just reversing the unit.
However, if a manufacturer built a wall-shaker with two enclosed HXs,
with their air inputs and outputs controlled by gates, to switch functions..
That could work, but the AC would be much larger and costlier.
