06-29-14, 04:20 PM | #1 |
Putting radiator in front of mini split
Alright . Today . I checked with a sprinkler set it to spray on the mini split coils outside . It dropped the exhaust heat from 115 degrees . To 88 degrees . That was about 20 minutes .Believe it dropped it 400 watts i cant remember. So instead of spraying it in and all over the coils . I want to put a radiator in front of mini split intake and run the cold well water through it to help drop the intake temp and raise efficiency of my mini split . I am on a well. Not city water. Any ideas of ways to do it . For now itd be a open loop . Then i will make it like a closed loop for winter to increase my heating efficiency. Any one got any ideas of how to do it .
06-29-14, 07:39 PM | #2 |
Just go to your local pull a part junkyard and grab a radiator the right size out of any newer car. If you want to do a wraparound, grab two. It is amazing how thin and light modern car radiators have become. They're cheap, too .
07-01-14, 08:40 AM | #3 | |
Later when i do one with a closed loop . I want to fix it with some sort of a controller that keeps the temp kinda like the geothermal. Dig the shallow holes and drop down some pipe so durnin the winter i can benifit from a radiator helping keep it a little warmer. And i wont be pumping all that water up from my well |
06-29-14, 08:36 PM | #4 |
Or just use a water to refrigerant heat exchanger. AKA homebrew geothermal system.
07-01-14, 08:41 AM | #5 |
07-01-14, 07:00 PM | #6 |
You would have to void the warranty. If you're thinking about doing a water-source heat pump for the winter, don't do it to your shiny new (expensive) mini-split unit. Grab an ugly (brown or beige box) window unit off craigslist for $50 or less and have your way with it. If you read the manifesto, it's all spelled out in plain english. The knowledge and skills gained from a small-scale project is well worth the time spent. Plus, if you do it right, it will save you even more money than an air-source unit.
07-04-14, 06:56 PM | #7 | |
