Old 06-05-17, 12:41 PM   #621
stevehull
Steve Hull
May was good for my 12.7 kW STC system.
2170 kWhrs
Used 2070 kWhrs and banked 100 kWhrs.
Steve
Old 07-01-17, 03:30 PM   #622
pinballlooking
pinballlooking's Avatar
12.5 kW array we generated 1,823 kWh June 2017. This was the lowest June we have had.
We made 141 more kWh than we used. My oldest son is learning to drive in the Volt so we charged the car more this month than normal.
June 2017= 1,823 kWh
June 2016= 1,952 kWh
June 2015= 1,994 kWh
June 2014= 1,995 kWh
Highest one day June 2017 = 77.4 kWhs
We have banked 886 kWh for the winter.
Our system lifetime production is 79.1 MWh
Other solar producers show us your numbers for June when you have them.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 07-02-17, 02:39 PM   #623
where2
DIY Geek
My 4.4kW array
Apparently 2017 was rainy...
June 2017 = 458kWh
June 2016 = 541kWh
June 2015 = 588kWh
My electric bill was $74.66 for 701kWh delivered. (I never bank any kWh forward).
My system lifetime production is 23.6MWh
Old 07-04-17, 11:47 AM   #624
stevehull
Steve Hull
June was an good month with production from a 12.7 kW array being 2144 kWhrs. May was a bit higher with 2170 kWhrs.
No electric bill for those months (and July as well).
Am really looking at a Bolt and adding another sixteen 270 W panels to my forty eight panel existing system. That should add enough juice for my future EV driving needs.
Steve
Old 07-04-17, 12:18 PM   #625
pinballlooking
We now have 71,793 solar powered EV miles on our Chevy Volt. Even with gas prices low the savings really adds up.
You cannot get much cleaner driving than EV and solar power.
EV Chevy Volt -
Daox (07-05-17)
Old 07-26-17, 12:18 PM   #626
pinballlooking
This is my power cost for the last two years $100.88. This includes power to charge my Chevy Volt 36,000 EV miles during this time.
This is an export form my power Company. we can not off set the meter charge but they pay us wholesale for our extra power once a year.
EV Chevy Volt -
The Following 2 Users Say Thank You to pinballlooking For This Useful Post:
jeff5may (07-31-17), mmaritz (07-29-17)
Old 07-31-17, 09:06 PM   #627
pinballlooking
12.5 kW array we generated 2,049 kWh July 2017. This was the first month this year that was over 2 MWh
We made 444 more kWh than we used.
July 2017= 2,049 kWh
July 2016= 2,044 kWh
July 2015= 1,896 kWh
July 2014= 1,981 kWh
Highest one day July 2017 = 79.1 kWhs
We have banked 1,330 kWh for the winter.
Our system lifetime production is 81.1 MWh
Other solar producers show us your numbers for July when you have them.
EV Chevy Volt -
Daox (08-01-17)
Old 08-01-17, 08:14 PM   #628
where2
DIY Geek
My 4.4kW array:
July 2017 = 558kWh
July 2016 = 607kWh
July 2015 = 546kWh
July 2014 = 475kWh
Today officially marks the anniversary of 4 years with an on-grid PV system. To date, I've generated 24.1MWh total.
The Following User Says Thank You to where2 For This Useful Post:
pinballlooking (08-01-17)
Old 08-02-17, 04:49 PM   #629
antdun
I'll be getting my system online this month as soon as my power provider installs the net meter, so soon I'll have production stats for my 6.38 kW system in Utah.
DIY installed a 9.98 kW rooftop solar system with REC TP2 panels, SolarEdge SE7600a-us grid tie inverter, power optimizers, & Snap 'N Rack mounting system.
antdun is offline   Reply With Quote
Old 08-02-17, 04:59 PM   #630
pinballlooking
Post a picture of your install.
I look forward to your production numbers.
EV Chevy Volt -
