Old 10-07-13, 05:40 PM   #21
Yes I got a factory made and insulated line set. Will do on the drain. Thanks for the tip.
My tools probably won’t be here for a weekend install be we will see.
Old 10-08-13, 05:18 AM   #22
WyrTwister
You can start the install . Prepare the place the outside unit is going to be set / located . Run the A/C power to the outside unit . Scope out where the indoor unit will hang & the hole in the wall to feed the line set through .
Screw the mounting bracket to the wall & maybe cut the hole in the wall ?
Are you running the line set down an outside wall ? I used some white metal down spout gutter to cover the line set .
MiniSplitCondensor07-06-2013_zpse6aecf0f.jpg Photo by WyrTwister | Photobucket
With a disconnect and liquid tite flex to cover the electrical .
MiniSplitCondensor07-08-2013_zpsaf78ed8f.jpg Photo by WyrTwister | Photobucket
You can gather incidentals , like screws , hand tools , the black sticky " cork " insulation tape ( to cover / insulate the service valves & remainder of the copper lines ) , metric Allen wrenches for the service valves , etc. .
I assume you will be penetrating an exterior wall for the line set to go through ? Is the exterior wall brick ? You will need a core bit and rotary hammer drill .
Otherwise , you will most likely need a hole saw and a drill sufficiently powerful to operate it . Most likely a 1/2" drill .
God bless
Wyr
Old 10-08-13, 02:11 PM   #23
It is all coming together. I got my nitrogen gauges in the mail today. My manifold gauges come Friday.
Micron gauge and Vac pump will be here Friday and mini split Thursday. I pick up my rental nitrogen cylinder tomorrow.
I got the wire, breaker and disconnect switch flexible conduit 3" hole saw.
Old 10-13-13, 09:01 AM   #24
WyrTwister
Originally Posted by BMR View Post
Just a heads up that you may find you need fractional, not metric flare and/or crow's foot wrenches. Check your equipment and lineset when you get them.
Best I remember , mine were metric ? Used the crows foot on the 3/8" torque wrench . Set at 03:00 o'clock or 09: 00 o'clock position ( perpendicular to the handle of the torque wrench ) .
I read that would give the most accurate reading with such a set up . Used a flare nit wrench , for backup , on the small line .
On the big line , best I remember , I did not have a crows foot large enough for the big flare nut . I used the crows foot and torque wrench on the " body " of the fitting and a big crescent wrench on the big flare nut .
The paper instructions had a typo on the torque specs . I had downloaded a pdf file of the instructions . They had the correct info .
So , if the numbers do not sound right , double check .
My outdoor unit had a plastic fitting to go on the bottom . Instructions said this is a drain for water , when the HP went into defrost and melted frost . Some / most of the water may run down inside the metal housing .
I bought a few feed of hose to go on the plastic fitting , but the fitting stuck down too far to allow the unit to set level , on the concrete .
Another trip to the store & bought 8' of 4" x 4" treated post . I cut 2 blocks for the " feet " of the out door unit to set on & screwed the " feet " to the 4" x 4" blocks . This gave plenty of clearance for the drain fitting and hose .
MiniSplitCondensor07-04-2013_zps7dfe4994.jpg Photo by WyrTwister | Photobucket
God bless
Wyr
Old 10-14-13, 09:07 PM   #25
Thanks for the tips I just ordered a 24mm crowfoot. I hope to do the install this weekend. All my tools except 24mm crowfoot are here. The Mini split is here vacuum pump gauges.... I can’t wait to get this installed.
Old 10-15-13, 12:30 AM   #26
WyrTwister
Best of luck . Please let us know how it goes . The good , the bad and the ugly . :-)
And photos are nice . :-)
God bless
Wyr
Old 10-18-13, 08:26 AM   #27
I am one step closer. My 24mm crows foot came in the other ones are flare nut wrenches. But I was not finding a 24mm flare nut crows foot for a decent price. This one should work fine.
I will post the good bad and other with some photos when I am done. Hopefully it will help others I know the post here have helped me get this far. Without reading post here I wouldn’t even have taken on this project but now I am excited to do the install.
I found a guy (HVAC one man company) to bless my install and sign the card for a decent price.
You can find all the tools I bought for the install it this post.
http://ecorenovator.org/forum/geothe...nstall-12.html
Old 10-18-13, 09:34 PM   #28
WyrTwister
Default Crows foot
I bought a Harbor Freight metric set of flare nut crows feet and " open end " metric crows feet . 19 mm was the biggest in that kit . :-(
God bless
Wyr
Old 10-23-14, 12:17 PM   #29
yeltrow
Default Heat Pump Gauges?
This is a GREAT thread. Getting a shopping list confirmed by knowledgible people is VERY helpful. Thank you to all of the contributors.
I saw some "Heat Pump Gauges" on Amazon (Search for item B004N157NC ). I'm new enough I couldn't post a link. Any drawbacks to purchasing these to do some diagnostic work on my heat pump? I would like to install a UV dryer on the system to help find a very slow leak.
yeltrow is offline   Reply With Quote
Old 08-11-15, 10:37 AM   #30
There is a complete list what I used here.
