Old 02-24-14, 04:35 PM   #11
WyrTwister
Originally Posted by nokiasixteth View Post
Brand is Kozykool
Model is 12HRDN1
It is 12,000 btu cooling and 13000 btu heating.
Has the toshiba compressor ive always had good luck with toshiba . Weather or not its a dud . Only time will tell.
How many sq ft do you plan to heat / cool ?
God bless
Wyr
Old 02-24-14, 05:16 PM   #12
nokiasixteth
I usually just heat and cool around 556 sq at night i heat and cool just the bedroom 234 sq and sometimes ill open both doors and get 1050 sq ft the whole house. Burt normally its 556 sq.
Old 02-25-14, 08:53 AM   #13
nokiasixteth
Just checked . On full heat 5 leds on it is 120 degrees inside. Heats the room up really quick
Old 02-25-14, 04:19 PM   #14
BeerGrylls
The 12hrdn1 seems like one of those unbranded plqtform builds just like my hrnf1, it is also in the Midea catalogues. The compressor is designed by Toshiba and some even branded as Toshiba but the actual manufacturer is a Chinese company just like everything else pretty much. I assume it has a single rotary compressor. Once the indoor unit will vibrate like hell and be noisy, just take it apart and pack grease in the blower end sleeve rubber support. If it looks like mine... I think my cheapo IR was not showing more than 36 C but it seems to have a hard time with some surfaces.
Cheers F
BeerGrylls is offline   Reply With Quote
