Old 06-23-13, 06:59 AM   #11
damo
Hx will be ordered directly from manufacturer (http://www.klingenburg.de).
Fans are EC type and their input signal is either pwm or analog voltage (which is almost the same - filtering pwm gives you analog voltage. Inside motor is variable frequency driver and motor is bdlc. I assume this frequency won't disctract my girlfriend... anyway since we have 2kids and she owns 1/2 of the house it will be easier to replace fans tha replace her
damo is offline   Reply With Quote
Old 06-23-13, 11:47 AM   #12
Thanks for the link to the HX manufacturer. I think I will need two HRVs for my place, so I'll be needing another HX.
Originally Posted by damo View Post
...Inside motor is variable frequency driver and motor is bdlc...
This is very interesting, I didn't know that these fans have a variable frequency driver inside. This opens up all kinds of interesting hacking possibilities.
Can you explain what "bdlc" means?
...filtering pwm gives you analog voltage...
I'd be interested to know how you go about filtering. I tried putting a large cap in parallel with the fan and the result was no variable speed. Please tell me how you are going about this.
... it will be easier to replace fans than replace her...
damo, it is good to know that you are a practical man... and know how to build noise filters.
Old 06-23-13, 01:19 PM   #13
damo
Ac, 'dblc' is a typo, I meant 'bldc' which stands for brushless dc motor.
These motor have 24v supply, control input (pwm or 0÷10V) and also tacho output so they are very easy to control. Inside electronic converts input signal to variable frequency signals which drive motor.Motor itself I think has 3 phase winding and is fed by var. freq. square wave from electronics. You can look for datasheet, full name of the motor is D 6424/2tdp. It is ebm papst custom made for Sun computers. There are two types 89 & 109W.
If you filter pwm you get dc voltage which varies with duty cycle. I think I will use pwm method since it is so easy on arduino.
Old 07-07-13, 02:30 PM   #14
damo
Got the motors (2 for 45$ ) They blow like hell..
Still looking for cheap CO2 sensors. Anyone knows where to get them for good price? Store that AC Hacker linked don't have them anymore
I plan ti implement CO sensor too.
Old 07-08-13, 10:38 AM   #15
...Still looking for cheap CO2 sensors...
Try ebay.
I saw some for about $50(US).
