Go Back   EcoRenovator > Improvements > EcoRenovator Blog Discussion
Old 09-21-09, 08:01 AM   #1
SVOboy
SVOboy's Avatar
Default DIY Ground Source Heat Pump – Part 6: Testing Plastic Welds
This entry is part 6 of 6 in the series DIY Ground Source Heat PumpNow that AC Hacker has his home made plastic welder all put together, he could start doing some welding.* But, how was he to know if his welds were all sealed perfectly tight?* They certainly need to be, otherwise the system [...]Post from: EcoRenovator.org
More...
