Old 04-08-14, 12:54 PM   #1
buffalobillpatrick
Default wtw radiant heat pump condenser vs evaporator size
So far I have read some conflicting info.
Should condenser be same size as evaporator, or bigger (1.5x), or much bigger (2x)?
Old 04-08-14, 01:40 PM   #2
The recommended size (by design) is a tad bigger. As a general rule (when oversizing heat exchangers as I recommend), the condenser should be the same size or bigger.
