Old 09-08-15, 09:59 AM   #11
oil pan 4
Land owner
LED head light with high beam on.
Old 09-27-15, 01:02 AM   #12
oil pan 4
Land owner
Building my own furniture.
Some of the corners are still hot from welding.
Need a new entertainment stand. Cheap particle board junk from walmart is between $100 to $200 and falls apart after a few years. My current one sucks, bought it used off CL 2 years ago. It sags and not all the cabinets close and I fear its going to collapse any time I move it to clean and dust behind it.
The nice metal and wood entertainment stands like I want to build start at $900 if I wanted to just buy one.
Between the steel, wood, casters, paint I will have well under $300 in it.
jeff5may (11-07-15)
Old 09-27-15, 11:50 PM   #13
oil pan 4
Land owner
My small halogen work lights after being on for an hour or 2.
I believe they are 100 watt.
Whatever the lowest common wattage for a given halogen tube size is what I typically run.
Old 09-30-15, 01:45 AM   #14
oil pan 4
Land owner
32 inch red neck LED light bar.
ID:	5974   Click image for larger version
Old 10-09-15, 11:44 PM   #15
oil pan 4
Land owner
Gas range.
Old 10-10-15, 12:04 AM   #16
oil pan 4
Land owner
In other news I tried out a FLIR E6.
I don't care for it.
It appears to take a "bleached out" regular image and over lays it with a thermal image.
The image looks lower resolution then a flir i7 but the flir ligature claims its the same resolution.
I would say save your self $600 to $1,000 and just buy the "inferior" i7.
Old 11-07-15, 11:28 AM   #17
oil pan 4
Land owner
Wall heater with pilot light and while running.
ID:	6195   Click image for larger version
Old 01-28-16, 11:03 AM   #18
oil pan 4
Land owner
72kw gas turbine compressor, turbine side.
The flir is aimed at the combustion chamber cap.
ID:	6579   Click image for larger version
Old 01-28-16, 11:37 AM   #19
pinballlooking
pinballlooking's Avatar
Nice picture.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 01-31-16, 11:57 AM   #20
Elcam84
What kind of generator is that. At 72kw it's a really small gas turbine. Most I'm familiar with start around 4mw. IE lm1500 LM2500 running a power turbine and a generator. 72kw would be more like a generator cart/ start cart.
Makes me want an ir camera even more. Before we move and start looking at houses in will have one to check over the houses we look at.
diesel engine, efficiency, flir, insulation, lawn mower
