Old 10-24-08, 05:53 AM   #11
insaneintenti0n
YAY i'm done!!!!
OMG, i'm exhausted.
No pictures, mainly cause it all looks the same, just much darker since i blocked out all the holes.
I really need to get my kitchen up to more than 60 degrees before i really have a good test to see how things are. but that hasn't happened in a while.
insaneintenti0n is offline   Reply With Quote
Old 10-24-08, 06:13 AM   #12
Awesome! I'm very interested to see how well this works.
Old 10-31-08, 06:38 AM   #13
insaneintenti0n
floor's still cold, surprise surprise. but, might be taking longer to cool down after it finally warms (WHEN it finally warms)
anyway, yesterday's project was to attached the heat dish that i wanted to the wall in my kitchen. i had some initial obstacles, and i still have another to overcome.
Here's the heat dish
they're awesome, used correctly. Sitting on the ground, pointing at you. They're 1000W (instead of the 1500W that most space heaters are) and since it's a directed heat, you warm up FAST (not the room so quickly, but it does over time)
They have a built in safefy buzzer. If they get tipped, they go BZZZZZZZZZ. all it is is a button that is pressed when it lays flat. figured that would be no biggy. if it's pushed against the wall it should be fine. well, it is, for the most part, but something about it facing down sets the buzzer off after a certain period of time. so, i eliminated the buzzer.
(Crappy phone pix)
but i just changed the wiring some to take the safety crap out of the system (smart, right?)
this image shows the heater pointed down towards the COLD floor, and you can kind of see the difference in the ceiling heights between that and the ceiling fan
I finally measured the ceilings. 10ft max (it slants, starts around 8', then goes up to 10') in the extension, 8.5ft in the main part.
But, now i have another problem. since heat rises, it's triggering the thermostat VERY fast. For the most part i use these as either On of Off. not medium, low, whatever. So, i might now also bypass the heat monitor (looks to be a piece of ceramic, silicon, or something, that i guess changes resistance as it heats and cools. Not sure what happens if i take that out of the system. I might find out though
Though, of course, I could just buy a radiant heater that's made FOR this (Like this one) but that's $100 - $200, and 1200W - 1500W vs. $60 and 1000W.
Old 10-31-08, 09:48 AM   #14
Now that I'm thinking about it, it doesn't seems surprising that the floor is cold. With the heated floors in my house (also covered in ceramic tile), you can even tell a huge difference between the heated and unheated section. The heated section doesn't really feel real warm, but the unheated section does feel cold. If you put one hand on one section and another on the other, you can really tell the difference.
Old 10-31-08, 10:11 AM   #15
insaneintenti0n
yup. real tile sucks. lol.
at least for the most part that section of the kitchen should be airtight with all the other work i did. funny enough, this year, my main floor is WAY warmer than my top floor with using the house heat. that was the opposite last year. so i did something right, or something wrong. might re-bleed the 2nd floor radiators just to make sure, but they were all warm this morning.
Old 10-31-08, 06:15 PM   #16
insaneintenti0n
and, another toy to play w/. I HAVE to stop collecting heaters.
Oscillating option, 400w or 800w, $25 at harbor freight.
This vs. The costco one, $60, 1000w, no oscillation.
One of em is going back to the store.
Right now I have 3 heating dishes, 2 oil filed radiators, and a blower space heater.
Old 10-31-08, 06:24 PM   #17
Haha, nice collection. Now, you need one that attaches to a belt and you can wear it so you'll be warm all the time!
Old 11-18-08, 01:40 PM   #18
How is the new setup working out?
Old 11-19-08, 09:57 AM   #19
toyobug
avid DIY'r
toyobug's Avatar
do those "space heaters" work well
toyobug is offline   Reply With Quote
Old 11-20-08, 05:08 PM   #20
insaneintenti0n
those space heaters are AWESSSSSSSOME.
the floor. not so much. it's still cold. there's no hope. I could do radiant floors, but i can't see that being nice on my gas/elec bill.
i just rewired the kitchen heater again today. took out the thermostat control. it kept kicking itself off. now, that doesn't happen. yay. but i gotta keep an eye on it and make sure it doesn't cook itself.
