#1 |
![]() I'm on the lookout for a 150-250W grid-tie inverter for small projects, but the smallest I can find in my neck of the woods is 500W. I've read that inverters are most efficient close to max load, so any ideas how much I'd be losing if I put 50-150W through a 500W inverter? Would it be about the same as through a 1000W? If so, would it be better to buy the 1kW inverter now (anticipating future expansions), than 500W now and 500W later?
Also, is it true that an inverter's efficiency is higher when the input voltage is higher? Ie is a 1kW 24VDC->230VAC inverter more efficient than a 1kW 12VDC->230VAC inverter (all other parameters equal)? |
#2 |
![]() You'd really have to get those specs from the manufacturer. I would hope they have that data available.
#3 |
![]() They have 300W units on Ebay.. $99.99 shipped..
eBay Store - POWER INVERTER TRADE CENTRE: 12v pure sine wave inverter, 12v modified power inverter, 12v solar panel 600W for $199.99 Edit: Sorry, I didn't see you were in Poland.. Last edited by Xringer; 01-30-10 at 08:02 PM.. Reason: Poland |
