Old 06-29-10, 05:49 PM   #1
iggy1
Default WattSun DC motor
Hello, I have a WattSun TR-100 Solar Tracker. The motor has burned out.
Does anyone know of a source? The motor operates on 24V DC, has a worm gear drive, is 4" long from mounting face to bearing end and is 2" in diameter.
The distance between the two mounting screws is 2 1/2" center to center.
The unit was purchased from Array Technologies, New Mexico in 2001. Their item number was WSV75-04S. Any help will be much appreciated. Cheers
iggy1 is offline   Reply With Quote
Old 06-30-10, 11:15 AM   #2
This site has the tracker for sale. They might be able to get you parts:
Wattsun Single and Dual Axis Trackers - Solar Panel Mounting & Trackers @ AltE
Old 06-30-10, 05:14 PM   #3
I looked at the TR55 tracker and it looks like they are using Satellite dish movers. Linear actuators.
http://www.altestore.com/mmsolar/oth...tion_Guide.pdf
Those things are available on Ebay.. I use one on my DIY tracker.
http://ecorenovator.org/forum/projec...r-project.html
Edit:
Never mind.. I just found a pdf for your system. It looks like a special motor..
http://www.wattsun.com/pdf/Wattsun_T...tion_Guide.pdf
Have you tried to repair the motor? If the coils are not melted or open,
maybe it's just an End-limit diode or switch?
Old 06-30-10, 06:17 PM   #4
iggy1
I have tried all of those sources. I think that the DC motor that I need may be incorporated into the Jaeger SMR-1224. I had a exploded drawing of the SMR-1224 and item number 12 looks exactly like the motor that I need. Are any of you familiar with that motor. My burned out one has the dimensions mentioned in my first post. Can that motor be bought seperatley? Cheers
Old 06-30-10, 07:11 PM   #5
Do you know exactly what is wrong with your motor?
I've repaired a few motors by finding faults in the power supply-to-motor circuits
and replaced the brushes on a lot of DC motors..
Sometimes a dish mover will hit the end-limit switch and not be able to move
back the other way.
The motor is still good, but the end-limit diode has gone bad or has a loose connection..
Here is how they are connected to allow the motor to reverse after hitting the end limit switch (which cuts the power).
Electronic Projects at Red Rock
I had a mechanical hangup on my mount, which loaded down and stopped the motor,
but the fuse protected it from melt-down. I was lucky, just had to replace a fuse..
Old 06-30-10, 07:21 PM   #6
iggy1
Default motor burned
It is burned badly. My fuse did not blow. As I stated in a previous post, I think that the motor may now be used in the Jaeger SMR-1224. If I could identify it as such, I would be happy to buy one. Cheers again
Old 06-30-10, 08:17 PM   #7
Maybe you can find a used one. It seems like Jaeger isn't around anymore.
When I was a kid, we had a motor repair shop in town.. They used to strip them down
and re-wind the armature with new wire.. Too bad those days are gone..
As a last resort, you might have to ditch the motor and add-on a regular dish actuator.
There a lot of examples on this page: LED3X Solar Tracker Assembly
