Old 03-11-14, 09:30 PM   #21
nokiasixteth
Does any one have the Ge Geospring 50 gallon hybrid water heater ?
Shop GE Geospring 50-Gallon 120-Month Hybrid Water Heater ENERGY STAR at Lowes.com
Old 03-11-14, 10:00 PM   #22
Someone here did a teardown and it uses a refrigerator compressor. Which means the efficiency won't be as good as with an A/C compressor and it would be slow at heating water.
nokiasixteth (03-12-14)
Old 03-12-14, 03:24 AM   #23
WyrTwister
Way too $$$ for my blood ! :-(
God bless
Wyr
Old 03-12-14, 01:32 PM   #24
nokiasixteth
God bless
Wyr
Mississippi power has $300 bucks on rebate . And i believe you get a tax credit of around 3 i remember the guy right would run around 700 bucks or so
Old 03-12-14, 01:39 PM   #25
nokiasixteth
Prob would do us good being only 2 lives here. Wonder how slow it would heat
Old 03-12-14, 06:10 PM   #26
the geospring is a hybrid unit. When it goes into "recovery" mode, the compressor shuts down and the sand hog elements take over. During this time, you burn lots of electricity to try to keep the tank hot. Once the water warms up, it goes back into "energy star" mode. So the time it saves you the most energy is while you're not using hot water (a lot of the time), or when you take a 3 minute shower (habits determine) or wash dishes.
By the way, there is no way to force the unit to switch modes, it's too smart. You just set the tstat and away it goes.
Old 03-12-14, 06:20 PM   #27
nokiasixteth
I thought that when you turned it to heat pump only it would only use the heat pump. Thats just to bad i had thought about getting one with a heat pump being i dont have a clue how to make a heat pump water heater.
Old 03-12-14, 06:41 PM   #28
nokiasixteth
Default Found this pic on adeno
What if you put it into heat pump only instead of hybrid mode so it still would use the heating elements ?
Old 03-12-14, 07:41 PM   #29
I've made up my mind: I am going to hunt down parts and build one of these. I was just asked to swap out a 40 gallon electric water heater because one of the pipe threads has a leak at the plastic pex fitting! Reasoning is this: it's almost 10 years old, so this must be a sign of things to come. No joke.
With a donated water heater and a couple of window units sitting in line, I believe I can tackle one of these for under $100.
Old 03-12-14, 08:20 PM   #30
Is that an Ethernet port on the front?
