Old 11-25-13, 06:09 PM   #31
Exeric
Mastic didn't seem that messy to me. It's much thicker than paint so it doesn't drip. Overall much less messy than painting. You can't stop a duct air leak with insulation so the main thing is to always air seal ducts BEFORE insulating them. I'm not an HVAC guy either, though.
Exeric is offline   Reply With Quote
The Following User Says Thank You to Exeric For This Useful Post:
pinballlooking (11-25-13)
Old 11-25-13, 06:17 PM   #32
pinballlooking
pinballlooking's Avatar
There is a few places that I should go back over with mastic.
I should have added that a few weeks ago I sealed up the big leaks with mastic. But I really just covered the side that blows air. This time I went over both sides. I was able to let it dry for a few days before I need to use it.
Old 11-26-13, 09:28 AM   #33
Do you have any pictures of the install? Could you do a short write up on it?
Old 11-26-13, 12:34 PM   #34
pinballlooking
I did not really take any pictures. I did not think people were that interested. But I could do a write up on it if that would help someone else out in the future. Once it warms up here I will get the energy readings from the new motor. I have a TED5000 energy monitor and I took the readings before I took the old motor out.
Old 11-26-13, 01:16 PM   #35
I think that would be cool. I am interested. If I ever have my motor going bad I'd definitely consider it.
Old 12-02-13, 04:11 PM   #36
pinballlooking
Old blower motor used on high 714 watts
New green motor uses 418 on high. It saves 296 watts on high.
the new green blower motor uses 82 watts on low. It saves 632 watts on low speed. This will really help in the summer to circulate cool air.
I used a TED 5000 to get these measurements and it is measuring the whole house so I waited until no heaters or other stuff was running check before after about 4 times and took the average. So no this is not exact it is decent.
My home automation is hooked up to the low fan setting and I am able to turn it on and off with my phone or a network device or with code.
Old 12-04-13, 08:37 PM   #37
Servicetech
Servicetech's Avatar
Watch leaving the blower on 24/7 in a humid climate, it could revaporate the condensate durign the offf cycle. How many hours of motor run time will it take to pay for the motor?
Old 12-04-13, 09:19 PM   #38
pinballlooking
As you can see the low fan setting will help for payback. The high setting does save but it would take a very long time to get payback.
The payback is actually better than I thought it was going to be.
When you are using solar to cover all your power needs you have to look at how much solar would I have to add to cover this item.
Thanks for asking the question I am glad I did the math.
I won’t be leaving it on 24/7. It will be controlled by my home automation. The appliance that controls that knows the temp outside. It can get the temp inside and I can run the fan based on that info. It is totally programmable
Costs Calculator
ID:	3741   Click image for larger version
Old 12-05-13, 08:00 PM   #39
Servicetech
My standard 1/3 PSC motor only uses 345W on low speed, 480W on high speed. Payback time would be considerably longer... Motor is $250?
Is CFM the same with both blower motors?
Old 12-05-13, 08:03 PM   #40
pinballlooking
I paid $226 shipped I replaced ½ HP motor that did not have a low setting.
It would calibrate for the 1/3 HP so it would use less watts replacing a 1/3 HP.
They have some charts showing this.
You could probably buy it for close to $100 less than me at a whole sale price.
Here are some specs on SNTech Green Motor
http://www.davidonindustries.com/stu...20Brochure.pdf
