Old 12-28-13, 05:26 PM   #1
Default tool to staple down aluminum heat spreaders?
I'm to the point where I am putting down the aluminum heat spreaders in my office hydronic floor. However, I just tried stapling them with my hammer stapler and it really isn't cutting it. I tried swinging it, and hitting it with a hammer, both give less than stellar results. I'm guessing the next step is going to a pneumatic stapler? I highly doubt my electric stapler will punch through the .02" aluminum. Any other ideas?
Looks like Gary from builditsolar uses a pneumatic stapler: $2000 Solar Space + Water Heating System: Staple Up Radiant Floor Heat
Here is what I've gotten so far.
Old 12-28-13, 10:42 PM   #2
greif
a van down by the river
I used pneumatic stapler
Gary R
The Following User Says Thank You to greif For This Useful Post:
Daox (12-30-13)
Old 12-30-13, 07:59 AM   #3
Thanks, that is what I was thinking. I'll be borrowing one from my brother in law to finish those up!
Old 01-02-14, 03:52 PM   #4
opiesche
I used a couple of screw guns and drywall screws (6-8 per plate depending on length) for my installation. It's not quite as quick as stapling, but still fast and easy to do - screwing the plates down took about 10-15 minutes per room with two people. Also, after removing the carpet and padding, I never wanted to hear the word Staple again.
opiesche is offline   Reply With Quote
Old 02-10-14, 09:14 AM   #5
Just to follow up on this. I ended up borrowing a pneumatic stapler to do the work. I haven't used it yet, but nothing else I tried worked. I tried a spring loaded stapler, it wouldn't go in far enough. I didn't try my electric stapler and I did not try using screws.
Old 03-18-14, 09:57 AM   #6
I just wanted to wrap up this thread. I ended up using the pneumatic stapler and it worked like a dream. I had to adjust the pressure down to ~40 psi to not shoot the staple clean through the aluminum and still have it go in all the way. This took a bit of trial and error, but it wasn't bad. After I got it set, it worked so nice.
