Old 03-12-13, 05:49 PM   #11
Originally Posted by servant74 View Post
Y
The latest rage are 'heat pumps', where you use the energy to get, say a SEER of 10, is supposedly efficient enough to 'collect' 10 watts of heat for every 1 watt it uses, and allows you to re-deposit the heat elsewhere.
I hope that helps.
That is not what SEER is. SEER is "seasonal energy efficiency rating"
Heat pumps are measured in COP which is usually between 1 and 5, 1 watt of power for up to 5 watts of total heat out depending on conditions (but usually closer to 3)
Servicetech (11-09-13)
