Old 10-14-11, 11:29 AM   #11
cdig
Paranoid.
Those chemicals are on your clothes which touch your skin all day long. I wouldn't be bothered by the tiny amount you possibly might breathe in. I'd be more concerned with the particles of lint.
Good point... I'll maybe do a bit more research on this, but maybe I CAN actually just pipe my dryer vent into the furnace cold air return? I have the fan running constantly (at the advise of my local furnace repair shop) to circulate the air in the house and regulate temps better... so maybe this would help to reclaim the heat AND increase humidity in the dry winter air. Should be easy enough to rig up a filter pre-heating duct.
cdig is offline   Reply With Quote
Old 10-14-11, 11:39 AM   #12
That sounds like a good idea.
Though I don't think having the fan on contantly is really required. Maybe turn it on for a few minutes every half hour or so.
Old 10-14-11, 01:49 PM   #13
cdig
the idea behind leaving the fan running is that it takes less power to keep the motor running than it does to constantly start it up. It also circulates the air more so that the hot air that rises into my attic 1/2 story gets reclaimed and distributed throughout the house. At least that's what the pros tell me
Old 10-14-11, 01:57 PM   #14
Starting and stopping the fan isn't a big deal at all. Keeping it running is going to wear things out and use way more power. Its kinda like the old line 'it takes more energy to heat up a cold house than keep a house warm' which is completely untrue.
It definitely will circulate more air and keep things mixed up better. However, I'd probably do some testing to see how much you can turn it off and still get the same benefit. Just setup a few thermometers around the house (high and low in rooms) and monitor them. I bet you can reduce your power consumption of that blower a ton and still get the desired effect.
Old 10-14-11, 02:27 PM   #15
cdig
yeesh there's alot of opinions out there! Furnace fan - "ON" or "AUTO"? - Digital Forum
What I gather from this forum is that it depends greatly on how old and drafty your house is, your personal preference, and your furnace setup. I'm going to have to go back to my furnace experts and get some clarification I think.
Old 10-17-11, 10:30 AM   #16
Higgy
The Gardener
We don't use bounce sheets. That stuff is nothing but garbage. We use the dryer balls that are sold from...good lord what's the company called...Norwex I think. Anyway they work great and we never have an issue with static cling. And they've lasted us for years. We also use Shaklee detergent so it's all very ecofriendly stuff we use. So diverting it shouldn't be an issue. My clothes barely give off any smell...unlike some people who use Tide and what not who's clothes stink. I have a very good sniffer and I hate lots of smells.
Old 12-02-11, 07:23 AM   #17
gasstingy
If I might chime in, I think that if the air flows out of the dryer vent and then bubbles out of the water, you will have created a humidifier. I doubt the heat value will be much.
OTOH, Edison was ridiculed about his ideas for a light bulb, but he kept notes on what did and didn't work and eventually he succeeded. That's what I love about these forums, we try to prove whether an idea works or not and then move on. So, give it a try, keep good notes and good luck with your idea! Track your heat output and the humidity levels so you can share the results with the rest of us. {I looked and could not find where you are from, so I don't know if humidity is an issue for your area. It really is an issue in my area.}
Old 12-02-11, 11:22 AM   #18
Seems to me that if the 'change of state' of the water in the dryer air could be exploited, great progress could be made in dryer heat reclamation.
Here is a diagram of a condensing gas water heater...
The gas from the heating flame is circulated through a helical tube that runs through the water in the heater. At some point, the water in the flu gas condenses, imparting the heat of vaporization into the water. Some kind of drain is required to deal with the condensate.
What would be key is to find out what the temperature is when the water vapor turns to liquid water. Also, the condensate will need to be delt with.
Here's another diagram of a condensing demand water heater, with an indication of the temperature of the stack gas...
It may be that, owing to the the temperature of liquification of water-vapor, water pre-heating may be a better objective than air heating, .
ID:	1895   Click image for larger version
Old 04-15-12, 11:13 AM   #19
6Monty6
Default Clothers Dryer Heat Exchanger HE26
Here is what I created. Go to youtube and look up Clothes Dryer Heat Exchanger HE26.
6Monty6 is offline   Reply With Quote
The Following User Says Thank You to 6Monty6 For This Useful Post:
diyEthic (05-20-12)
Old 04-15-12, 09:48 PM   #20
Looks pretty cool! I wonder how lint build up will be to clean out of the barrel? I assume you've got some idea there since you've been playing around with this for a while now.
Here are the videos 6monty6 has posted on youtube:
