Old 11-08-09, 08:22 PM   #1
GvilleRenovator
Greening Renovator
Default Sealing my Air Ductwork
After looking around in the attic, I noticed that the ductwork was leaking at nearly every joint. I have not done this before, nor did I stay at a Holiday Inn Express last night. I HAVE watched a crew replace the duckwork in a rental of mine though. I watched very closely thank goodness.
This is how most joints looked before I started.
I cut off the tie wrap holding the flex duct.
Oddly, on this side of the house, each duct was sealed with duct tape. Even after 20 plus years, the duct tape was holding strong.
After removing the tape and straightening the tabs some, I removed the steel adaptor from the duct board.
At least at the beginning the joint probably did not leak as much. Since the tiny bead of silicone was coming off though it leaked now.
ID:	486   Click image for larger version
ID:	487   Click image for larger version
ID:	488   Click image for larger version
ID:	489   Click image for larger version
GvilleRenovator is offline   Reply With Quote
Old 11-08-09, 08:37 PM   #2
GvilleRenovator
Greening Renovator
Default Part 2
I used Mastic from a local big box Hardware store.
I slathered up the joint good and messy.
Carefully slid the adaptor back into the duct board and bent the tabs back over to hold it in place. (Be Careful NOT to cut your fingers!)
Then I slathered up the joint on the ouside, making sure to get more on than I figured was needed just for good measure.
I also put a generous amount of mastic on the outside of the adaptor for the next step.
Name:	CIMG3019 Mastic.jpg
ID:	491   Click image for larger version
ID:	492   Click image for larger version
ID:	493   Click image for larger version
ID:	494   Click image for larger version
Old 11-08-09, 08:50 PM   #3
GvilleRenovator
Greening Renovator
Default Part 3
Then I slid the inner plastic portion of the flex duct back on to the adaptor and put on a tie wrap to hold it in place.
Then another layer of Mastic over the duct to help seal things up.
Pulling the fiberglass back down and getting it covering the whole joint.
Then pulling the outer layer of the ductwork down and putting the last tie wrap in place.
I have finished about half of the house. I am doing both joints at either end of the flex.
ID:	496   Click image for larger version
ID:	497   Click image for larger version
ID:	498   Click image for larger version
Old 11-09-09, 06:57 AM   #4
Nice work. It looks like you could have been loosing tons of air out of that leak! Hopefully you'll see your energy usage drop accordingly.
How do you like the mastic? I tried to find it around here but ended up just going with aluminum tape (which I have yet to use).
Old 11-10-09, 11:58 AM   #5
GvilleRenovator
Greening Renovator
Thumbs up Mastic GOOD
I like the Mastic.
The only issue would be if you did not like getting your fingers messy.
(cleans up MUCH easier than Great Stuff)
I used a utility brush from the paint department for spreading it around. It was the closest thing I could find to what the A/C crew was using.
I have not found it in all of the big box stores, I had to keep my eye open.
I always keep a list of things to look for when I visit another city too.
Old 11-19-09, 09:34 AM   #6
Default Hot Air vs. Hot Water..
It's interesting that with hydronic heating, water is piped around the house rather than air. Since water has a much higher heat carrying capacity per unit volume,much less of it is required to do a particular heating job, so the pipes are much smaller and easier to route and insulate than air ducts.
Probably no consulation with your current project.
Regards,
