02-22-14, 12:24 AM | #11 |
Put a Kill-a-watt meter on your fridge and freezer.
My fridge and freezer use about the same amount, just under 1kwh per day so if you have 4 sun hours per day you'll need about 300 watts of PV per fridge or freezer if you are running a battery based system because of all the losses that you have with battery based systems, then size your battery bank for at least 3 to 5 days of no sun, longer if possible, drained to 50% state of charge, unless you like lugging around dead lead acid batteries. As far as splitting off the outlets, put a small sub panel in for those outlets that is designed for a generator with lock out switch for switching between grid and generator. |
