#11 |
![]() I just put in my first Gree HP. It seems like a nice unit but not as robust as the Fujitsu that I usually put in.
I would not put the unit where you may wish to stand doing dishes, etc. The cold air can be uncomfortable. I would also do two separate units as the efficiency of a double head unit will not be as good as two single units. |
#12 | |
![]() Quote:
Pic of house build attached. Thoughts? Last edited by Daox; 01-15-15 at 08:54 AM.. Reason: added pic |
#13 |
![]() On the ground floor, I would try to have one unit near your main entryway. Second unit would be in the master bath near the bedrooms. Or it could be in a connected hallway between bedrooms. Having a unit in the bedroom is nice, but some people are sensitive to the noise they make.
#14 | |
![]() Quote:
So, it looks like I'm going to have a tough time finding spots for two minisplits downstairs since both of them have to be on the north (kitchen) wall. |
#15 |
![]() After more thought ..
I now think it will be better to use one 18000 Btu and one indoor unit , as your floor plan is open you do not need two indoor units as much as other designs would. |
#16 |
![]() If I wasn't so limited on placement, I think two units on oposite walls would be best but that will never happen. One 1.5 ton unit on the kitchen wall will have to work. I will have a fan above the sofas and dining room table. Should work fine.
With the traditional unit upstairs, some the its cold air will also fall down the stairs to the first floor giving it a little "free" help. Austin |
#17 |
![]() I think you will be set with just the one unit and no other fans as the room is open , if you needed to go around corners then extra fans would help.
#18 |
![]() I live in a dryer climate , although the mini split we have in the living room / dining room does pump out a fair amount of condensate when cooling .
I have read many warnings about over sizing cooling equipment . One of the issues , they say , is poor performance at dehumidification . From what I read , the higher SEER equipment usually / always employ inverter / variable speed compressors . As the load cooling decreases , the compressor slows down accordingly . Does this mitigate , to some extent , the problems with over size equipment ? How would a 24,000 btu unit perform , over the season ? God bless Wyr |
