Old 05-06-16, 10:25 PM   #1
nibs
Default Asphalt covered styrofoam
Have a line on 4inch thick 2ft X 4ft high density blue styrofoam (probably roofmate) price is about $3 per pc ($12 per full sheet) Canadian or $9.60 us. Thirty cents US per sq ft.
It was used on a roof and covered both sides with hot tar.
I want to use it to insulate under a 2 inch floor slab with hydronic heat tubes.
The construct will be something like
water proof membrane,
1 or 2 inches of styrocrete,on grade, at about 1 cement 2 sand 6 or 8 ground up styrofoam by volume.
4 inches of tar covered styrofoam
piping and sand to just cover the pex heat pipe
2" normal cement possibly with mesh.
for a normal house hold floor.
My concern is with the tar, over the years it does not seem to have harmed the foam, but will the tar/oils be able to migrate upwards through the concrete?
Your thoughts would be appreciated.
