Old 04-24-09, 09:11 PM   #11
gascort
Originally Posted by larryrose11 View Post
Gascort,
Can I assume you do have an bungelow style attic space, where part of the ceiling walls are slanted?
I consulted a friend on an bungalow attic remodel. He did most of what I suggested, and he gave it an B+. Could have been an A if he did my full plan.
Here is the short of it: you need to seal the living space from the non-living space. This was done by creating an air channel between each stud with Cayno using It would be best if you could remove the thermal short circuit where interior drywall is nailed directly to the same stud that the outside sheathing is nailed to.
Yes, ALL of the ceiling slants, down to 4 foot high walls that meet it.
Cayno?
Old 04-24-09, 10:49 PM   #12
Originally Posted by gascort View Post
an interesting idea - would that help with the condensation too?
Yes, dark shingles on SE roof.
Yes, it should help with condensation because it would help to elimenate cold spots by adding more insulation, either way reducing your insulation is not going to be a good long term solution.
