08-22-16, 01:26 PM | #31 |
I posted about the crown on 10-07-15 it was not even on sale in the US at that point.
It has been out less than a year. The crown is a new series for them. The Terra was there top of the line before the crown came out. I have the Terra series.
08-27-16, 11:22 AM | #32 |
new coupon codes
I got some new coupon codes a while back if anyone needs one..
Spend 1k to 2k get $75 off with Gree1000 2k to 3k get $150 off Gree2000 3k to 4k get $225 off Gree3000 4k to 5k get $300 off Gree4000 Over $5,000 gets $375 Gree5000 I used Gree2000 because I just ordered the Crown 18,000 BTU w/25' lineset. Just had to be the first guy on the block, thinking about global cooling..
09-01-16, 04:50 PM | #33 |
Just an FYI.. I just got another notice about the above prices..
It says "Take up to $375 OFF for Labor Day" Here's the link to the Gree download center. (where to get the Crown wifi app).. http://global.gree.com/ywb/productss...ad/index.shtml Found the app manual.. http://global.gree.com/data/cms/arch...)/17121/sc.pdf
My hobby is installing & trying to repair mini-splits EPA 608 Type 1 Technician Certification ~ 5 lbs or less.. Last edited by Xringer; 09-01-16 at 05:25 PM.. |
