Old 12-02-11, 08:10 AM   #201
danxro
Dan_LASER
danxro's Avatar
Send a message via Yahoo to danxro
thanks for advice
but will ask something u can do 2 pics with the circuit?
one front and one back?
so I can see
track circuit
so I can make myself one like that
please
danxro is offline   Reply With Quote
Old 12-02-11, 08:15 AM   #202
danxro
Dan_LASER
danxro's Avatar
i dont have money now
to buy a circuit
my wife is pregnant
and all money goes to her
need to take care of her and the baby
and so we spent too much money on panels and batteries
Old 12-02-11, 08:55 AM   #203
Just Google MTM Tracker..
Here's what I found online.. solar tracker mod
http://www.demiurgiac.com/MTM%20schematic.jpg
giorgioart (04-25-13)
Old 12-02-11, 09:20 AM   #204
danxro
Dan_LASER
danxro's Avatar
thank you
Old 12-31-11, 03:34 AM   #205
danxro
Dan_LASER
danxro's Avatar
dear sir XRINGER
Thanks for the scheme
I built two pieces of solar traking
works but I have a little problem
How do I connect switches
of acttuator
If you do not mind to help me with this problem
thank you
Old 12-31-11, 10:04 AM   #206
Limit switches are installed to open the motor current flow,
when the mount reaches End-of-travel.
LED3X Solar Tracker Assembly
Diodes are installed across the switches contacts, so that reverse is possible,
after the month hits End-of-travel.
I used a satellite dish mover actuator unit, because it has build-in limit switches.
I had to buy a new model with 'limits', since my old unit didn't have switches.
Old 05-22-12, 11:11 PM   #207
Mobile Master Tech
Mobile Master Tech's Avatar
Hi Xringer!
I read this thread and am curious if you are going to do more than resistance heating with the electricity after sorting out the mount.
Have you thought of adding serpentine cooling loops to the backside of PV panels? If you did this, you would get cooler panels (boosting efficiency), a high percentage of the total solar energy as the heat you are looking for now, and you would still keep the hard won "high energy content" electricity for DC uses or inverters.
BTW-as you know, that Occam (Ockham) guy is on to something!
Craig
Old 05-22-12, 11:16 PM   #208
Mobile Master Tech
Maybe your wife would like the panels on the roof if you intergrate some Sanyo HIT doublesided panels into a new portico
Name:	Sanyo HIT double solar panels.jpg
Old 05-23-12, 06:25 AM   #209
The tracker PV is connected to my back-up battery bank. 500w is over-kill for the bank,
so I've disconnected the actuator motor on the tracker.
The solar part of the back-up system (to power sump pumps) was basically an experiment that worked.
But, maybe I should have just used a 48v battery charger, with a 120vac wall plug..
(At least until we hit we hit Peak coal in 2025)..
I am getting pretty good use out of my 800w fixed mount PV. It's heating my hot water storage..
I'm now starting to think, the best use of PV is grid-tie.
Old 05-31-12, 11:45 AM   #210
Originally Posted by Mike23 View Post
Xringer : I follow your project and I can say its a great installation so far.
I have a few questions about the parts where can I find these in a cheap price and within a good timeframe.
Jeff : I've seen a lot of Arduino projects, and these parts are great for practice but are they corresponding for a professional and bigger projects as well ?
I find most of my parts on Ebay. Those that come from China get here slow.
3 weeks is typical. US shippers average 1 week.
electric, solar, tracker
