#1 |
I mod my world
![]() It seems we have a hang out for house modding as well....
![]() ![]() whats the equivalent of my car mods here? Last edited by Piwoslaw; 10-27-12 at 02:28 PM.. Reason: Added picture |
#2 |
![]() Welcome to ER Weather Spotter. Good to have you here.
The ultimate goal IMO is a passive house. This is basically a house that needs pretty much no heating or cooling systems. Heating and cooling are by and far the largest users of energy in a household. After you get rid of them, your energy use is pretty minimal and a little conservation bring that down to practically nothing. There are also zero energy homes that are just that, they produce as much energy (or more) than they use. They traditionally aren't quite as efficient as a passive house. They use solar PV panels and/or wind turbines to make up for their increased energy use. They're still quite a bit more efficient than a normal home.
#3 |
I mod my world
![]() I thought that might be what the goal was. I have a degree in facilities management . thats what's a large chunk of that is, reducing costs of commercial buildings. Homes are not much different.
I still live at home, but I plan at some point to buy my own house so I guess now is the time to start thinking about what type I want to get. How does free renewable wood heat stack up in your guys mind? |
#4 |
I mod my world
![]() Do you guys have a wiki section yet?
#5 |
![]() It would be a superinsulated house.
Welcome to ER, Weather ![]()
#6 |
I mod my world
![]() I am surprised I never found this place before . Our house has 6" of cellulose insulation in the walls. All exterior switch and outlet boxes are boxed out to keep insulation. Ceiling has 18" of cellulose as well as 1" Styrofoam. We heat with trees from our own woods . Or from neighbors dead trees that they do not want. Free wood and it heats us twice. Once when cutting/splitting/ hauling and again when we burn it.
We have a propane furnace but its never used. Lots of south facing windows for free light and heat. |
#7 |
![]() Wood heat doesn't have to be low tech or wasteful.
I know someone who installed a special wood furnace central in his Straw-bale house. It is stone and steel about 5 ft high 4 ft around , you light a semi large fire in its main chamber, that fire ,smoke and heat flows in to a upper chamber where it starts heating the fireplaces mass. One morning fire throws heat all day, very efficient ![]() |
