Old 03-25-20, 05:40 PM   #1
pinballlooking
pinballlooking's Avatar
Default I bought a commercial -20 freezer to make into a powder coat oven.
Does any know if the compressor or other parts are worth more than scrap?
I have the MFG phone number so I see what they used for insulation. I hope the I don’t have to replace it.
But I will if I have to. I will be moving my oven controls and heating elements to this.
I bought this for $80 I could not build it for that much.
I do not know how much I will get in scrap for the coils.
ID:	8889   Click image for larger version
ID:	8890   Click image for larger version
ID:	8891   Click image for larger version
ID:	8892   Click image for larger version
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 03-26-20, 08:13 PM   #2
pinballlooking
It looks like I have to remove the insulation and put in new insulation.
We started on it today. All the cooling system has been removed.
We are using a scraper attachment on a Sawzall. It works amazingly well.
I have oven gasket and door latches on the way.
ID:	8894   Click image for larger version
ID:	8895   Click image for larger version
ID:	8896   Click image for larger version
ID:	8897   Click image for larger version
EV Chevy Volt -
Old 03-26-20, 09:06 PM   #3
What insulation are you going to go with?
Old 03-26-20, 09:51 PM   #4
pinballlooking
Either Rockwool or fiberglass.
But I am leaning towards Rockwool.
You out gas at 450 degrees so either one will work.
The powder coat cures @400 degrees.
It looks like fiberglass. To get Rockwool I have to order 3 packs. No one here stocks it.
I can do it much cheaper with fiberglass. One pack fiberglass $37.48.
That one pack will be enough. That will work for this oven.
Some of the scientific freezers can store flammable storage. Mine is not that type.
I wish it was that maybe I would not have to re-insulate. It will be a pain but I think it will make a nice oven when I am done.
It will also keep my build cost low that is important right now.
I have a standard house oven right now. I will be gutting it and putting its heating elements in this one. For now I will just use its controls. This should work good in a oven this size and will keep cost down.
EV Chevy Volt -
Daox (03-27-20)
Old 03-27-20, 09:28 AM   #5
pinballlooking
I have the top off. I don’t think I can reproduce the way the panels are held together.
I may just cut strips and screw or rivet it back together. It is about 2.5” thick I may expand that to 3.5”.
That would fit my insulation better.
EV Chevy Volt -
Daox (03-27-20)
Old 03-29-20, 12:55 PM   #6
pinballlooking
More progress.
Now some of the finer details to get it ready to put back together.
I will need to add some support. The insulation was a lot of the support before the new insulation will not give the same support.
Really just the top and the bottom needs the support.
ID:	8915   Click image for larger version
ID:	8916   Click image for larger version
ID:	8917   Click image for larger version
EV Chevy Volt -
Old 03-30-20, 11:10 AM   #7
pinballlooking
I have the trim pieces ready for final clean up.
I took the torch to one of the sides. The middle part is not flammable but the trim pieces is flammable.
They use a lot of masking tape that will need to be removed.
The door is the last piece that needs the needs insulation removed.
Then it is just final clean up add support and oven layout.
ID:	8919   Click image for larger version
EV Chevy Volt -
Old 04-02-20, 05:29 PM   #8
dguzzi
You need this? ------->Click image for larger version
dguzzi is offline   Reply With Quote
Old 04-02-20, 06:29 PM   #9
pinballlooking
What is that?
EV Chevy Volt -
Old 04-02-20, 07:29 PM   #10
dguzzi
Its an electrostatic power supply for powder coating. (makes the powder stick to the stuff you are coating).
Copyright ©2000 - 2020, vBulletin Solutions Inc.
