Old 02-15-13, 08:30 PM   #11
creeky
creeky's Avatar
What I hear Xringer saying is that I can plug my wall wart into my 12 volt battery bank and it will run my laptop without problems.
Xantrex says
"many models of electric blankets, coffee makers, laser printers and
other devices that regulate heat using a microprocessor that may not operate correctly"
I use all of these devices.
They go on to say "The more complex or state-of-the-art your demand is, the more likely you will want and need to consider a TSW (true sine wave) inverter."
Another site (DanRowe) states:
the following devices that will normally not work with modified sine wave inverters:
Laser printers, photocopiers, magneto-optical hard drives
Certain laptop computers (you should check with your manufacturer)
Some fluorescent lights with electronic ballasts
Power tools employing "solid state" power or variable speed control
Some battery chargers for cordless tools
Some new furnaces and pellet stoves with microprocessor control
Digital clocks with radios
Sewing machines with speed/microprocessor control
X-10 home automation system
Medical equipment such as oxygen concentrators
Another site (civicsolar.) states:
"Some appliances, such as microwaves, drills, clocks or speed motors will not produce full output if they don't use sine wave current, moreover they may damage the equipment. Some loads, such as light dimmers will not work without sine wave at all."
I'm not sure of Verdigo's need, but I live offgrid. I need to be able to plug it in and have it work. So, to those who actually plan to rely on their "solar" systems:
Non mppt solar controllers, square wave or modified square wave inverters ... they're the model t of the solar industry. they were useful at one point, but now we have better tech. ya, it's a bit more expensive. but do you want to get up to your cabin and find out x y or z doesn't work properly because you dragged decades old tech up when you could have spent a few extra bucks and be microwaving a quick lunch for the kids and then going for a hike?
A modern car is 30k average now. I don't see anyone opting for a Model T on their commute.
Old 02-15-13, 10:00 PM   #12
Nope, what I said was:
"some small 1Amp wallwarts will even run okay on 50+ DC (from my 48v battery bank)."
A new Dell laptop switching power supply takes 100 to 240v 50-60Hz @ 1.5A
The DC out is 19.5vdc @ 4.62A (90 watts peak).
That's a lot more power than a wall-wart. It might run on 50 volts DC,
I would have to try it to be sure..
There is no way it will run on 12vdc..
Old 03-12-13, 07:35 AM   #13
Acuario
MSW inverters are ok for some things BUT almost instantly destroy others - so beware!
The problem is due to the transient voltages on the switching edges of the 'square wave'. They can easily exceed the peak working voltage of some of the components used in modern transformerless power supplies.
These psu's (generally used as they are low cost and can deliver small amounts of power that is required for micro processor circuits) use capacitors that have to be rated above the peak voltage delivered by the supply. These are normally rated at 250VAC (in Europe). The transient voltages on the edges of the square wave from the inverter can be extremely high both in voltage and power and far exceed the working voltage of these capacitors - result - BANG.
I've personally experienced this on a number of occasions where customers of minehave plugged in brand new devices to their power systems and they have gone bang.
Typically any microprocessor controlled device (fridge, freezer, washing machine, water pump pressure control system, etc...) is potentially proneto this failure.
The solution is either a pure sinewave inverter or replace the power supply with a transformer.
Old 03-12-13, 08:19 AM   #14
Default sine wave vs. modified sine wave
Modified sine wave (MSW) will screw up a lot of things. My TV can't tolerate MSW and the radio make a terrible noise .
I quickly changed out to pure sine wave (SW) and regretted getting a MSW as I lost money when I switched out.
In my opinion, SW is the ONLY way to go.
Old 03-12-13, 11:40 AM   #15
Default Spike protection?
Maybe I've never seen any problems here is because I'm using 120vac models..?.
No visible voltage spikes on the MSW inverters I've been using.
I wonder if the use of surge protectors (or surge suppressors) would be useful?
I only use my main MSW inverter (2.5kW & 5kW peak) for backup during grid failures.
The inverter cost was a factor. Since it's cost (under $200) was about 1/4 the cost of a 2.5kW 48vdc sinewave inverter (back when it was installed).
Today, sinewave inverters from China are not as costly.
2000W DC AC Pure Sine Wave Inverter Off Grid for Wind Solar System DC12 24 48V | eBay
If I every zap mine, I'll go for a sine wave model..
