Go Back   EcoRenovator > Improvements > Wind Power
Old 12-07-10, 01:56 PM   #1
Default Wooden wind generator
Wooden blades? No, all wood (nearly) construction! Pretty cool actually. Doesn't produce much power though. But, it is pretty small too.
The Following 2 Users Say Thank You to Daox For This Useful Post:
HerbertMCarpenter (08-30-19), solarhotairpanels (12-29-20)
Old 12-08-10, 01:17 AM   #2
Ryland
I was just thinking about that wind turbine the other day, I read about it when they had the story in home power 8 years ago, my favorite part is the magnetic dirt from the driveway.
Old 12-08-10, 07:24 AM   #3
lol yeah I thought that was pretty ingenious!
Old 12-08-10, 10:25 AM   #4
Patrick
This one's cool too. More metal but more power. Real bearings help. Wood - AX, another wooden wind generator.
Patrick is offline   Reply With Quote
Old 12-08-10, 11:32 AM   #5
Ryland
It's projects like this that give otherpower credibility, sure they made a wind generator out of wood and it didn't perform as well as something you buy, but it performed as well as one made out of wood and on a budget could do, because it was designed well from the ground up instead of just tossing together random parts.
Old 02-27-11, 05:12 PM   #6
cdig
gawd I wish I had that much extra time on my hands...
cdig is offline   Reply With Quote
Old 03-12-11, 06:04 AM   #7
markocale
too much for me
markocale is offline   Reply With Quote
Old 03-27-11, 04:20 PM   #8
Angmaar
Guest
Posts: n/a
It's cool that it's made out of wood instead of plastic.
Old 09-07-11, 05:39 AM   #9
guerciofernando
Guest
Posts: n/a
I would like to thanks for the time you've contributed in composing this post. This is great.
Old 06-29-12, 09:54 AM   #10
alicetom222
The power ratings usually given by the manufacturers for wind turbines are nearly useless, in that they are determined at wind speeds much higher that you will normally see. A good rough formula to keep in mind in evaluating different wind turbines
alicetom222 is offline   Reply With Quote
