Old 08-02-11, 09:35 PM   #1
greif
a van down by the river
Default engine noise
hi
I have a 2001 john deere gator 4 x 2 with a 10hp single cylider air cooled kawaski motor and about 500 hrs. When cool the motor sounds fine but when hot (10-15 minutes) it sounds like it is going to fly apart, nasty raddling/shakens/slaping sounds with less power. When cooled it sounds fine again. Oil is fine and changed regularly.
any ideas what could be the problem and if it's rebuildable?
thanks
gary
Gary R
“If you want total security, go to prison. There you're fed, clothed, given medical care and so on. The only thing lacking... is freedom. ” ― Dwight D. Eisenhower
greif is offline   Reply With Quote
Old 08-04-11, 04:32 PM   #2
Quest
when in doubt: always check the compression.
Then, we can go from there.
Q.
Quest is offline   Reply With Quote
Old 08-13-11, 12:05 AM   #3
nibs
Try adding some Lucas oil treatment about 20%, imo, you squeeze the last work out of it, then put in a new engine.
