12-21-13, 01:41 PM | #11 |
Yep, http://ecorenovator.org/forum/solar-...r-project.html is the one.
I ended up using PEX on the return side (due to an ~90' pipe run). It does have better properties than PVC, but I may end up finding out the hard way that it is not enough. Mikesolar suggested in my other post to use a few feet of copper at the start of the return. Dr. Ben also specifically recommends against it: PEX in a Drainback System? A 'melted mess' picture is there... |
12-21-13, 05:25 PM | #12 |
I'm not a fan of PEX for anything that needs water temps above 70C (158F) although it is rated at higher than that, and definitely not when the temp could hit boiling like almost any solar system. Some of the home made panels won't get up there so I think that is fine but I have seen too many messed up systems from tubes blown out at the fittings.
The Following User Says Thank You to Mikesolar For This Useful Post: | buffalobillpatrick (06-09-14) |
