Old 03-07-16, 03:25 PM   #481
kostas
Btw guys, here's a sneak peak of the 2.0 diy hrv unit I'm currently working on.
Featuring two centrifugal EC brushless fans, 650m3/h each, post heating radiator, homemade countercurrent 600mm heat exchanger, freecooling bypass damper and fresh air exclusion damper, all of them driven by 5V step motors. And of course the arduino Mega.
Stay tuned!
kostas is offline   Reply With Quote
The Following User Says Thank You to kostas For This Useful Post:
MADIFI (02-06-22)
Old 03-09-16, 06:17 AM   #482
ferox
Here some new updates from my HRV very close to finish.
cutting the board with hand made tool, very cheap
ID:	6736 Click image for larger version
ID:	6738 Click image for larger version
assemble the parts
ID:	6740 Click image for larger version
testing the dimensions for the parts
ID:	6742 Click image for larger version
attach the sealings
ID:	6744 Click image for larger version
ferox is offline   Reply With Quote
The Following 2 Users Say Thank You to ferox For This Useful Post:
jeff5may (03-09-16), kostas (03-09-16)
Old 03-09-16, 06:31 AM   #483
kostas
Excellent work, congrats!
What kind of glue did you use for the foam?
May I ask how much did you pay for the Recair?
Old 03-09-16, 06:40 AM   #484
ferox
ID:	6746 Click image for larger version
case for the EC fan 24V 55W each at max. speed, diam 175mm bought from china ~40$
ID:	6748 Click image for larger version
the box have the bypass channel included on the right side, the dumper is not fitted yet.
end the finished product without the controller
ID:	6751 Click image for larger version
next to do:
- air filters
- controller - speed controll with ballace, flow sensor on exhaust and inlet air, and other feature.
- bypass dumper (maybe with 9g servo or a simple dc motor for on-off shuting
The controller will be one Arduino connected to internet for using Blynk app on my phone, very easy to use.
The sensors will be DS18B20 and for humidity sensing DHT22.
Old 03-09-16, 06:49 AM   #485
ferox
the heat exchanger from Recair cost me ~260 euro / pcs ~ 300 $ with shipping included for 2 pcs.
I don't know the name in english, something calling in romanian "prenadez"
after glueing I leave it for 5-10 minutes end than can be stitch together, like the glue for boots.
@kostas what kind of sensors do you use with arduino and where is placed?
Old 03-09-16, 07:33 AM   #486
kostas
I use the DHT22 for both temperature and RH.
I'll place them like this inside the HRV chassis:
  • Income fresh air (in the outside hood)
  • Fresh air right after heat exchanger for calculating the COP
  • Fresh air after post heater for reading the amount of heated air
  • Return stale air
  • Bathrooms return stale air (only RH reading) for triggering forced refreshing
Apart these I'll have another DHT22 placed over the oven in the kitchen for the same reason as the bathroom, as well as a relay on the motor of the kitchen hood.
I am currently finishing the dumpers using small Emax servos.
Just got an eye on Blynk, seems cool! Do you have any experience with that?
Old 03-09-16, 08:00 AM   #487
ferox
Thanks for info.
Yes Blynk is very cool, simple and free, if you wand you can do sophisticated apps with the phone. Try it and you will love it!
I have 2 working controllers with blynk and others in progress.
I'm not a coder but is not to hard to stitch together some examples and modify for your needs.
Starting something new you need a lot of time for learning. But now we have on internet a lot of tutorials and examples for learning.
With the hardware part I have good experience.
For the triggering RH sensors what kind of cable you used, how long?
Old 03-09-16, 08:20 AM   #488
kostas
I used a 6 pole cable, the one usually used for home alarm systems, 4X0.22mm+2x0.50mm. It is also shielded so you have no interference problems
I just bought a 7" china android tablet for controlling my HRV at home, I'll install it and give it a try.
Old 06-02-16, 06:33 PM   #489
bdgWesternMass
Thank you all for the past 49 pages of HRV/ERV info. I can't believe I read every post.
Here is what I'm planning for my office and I have a few questions I would love to get some feedback on.
My office is a 2 story garage that is 60 feet by 24 feet. The second story is unconditioned space and the first floor has 5" of blown cellulose wood cladding on the inside and outside and finally wrapped in galvanized siding inside and out. I don't consider it a tight building but I'm considering this project to vent my bathroom, kitchenette and a small shop and bring in fresh air.
I have plenty of space in the rafters so I leaning to a concentric tube system. The fresh air tube we start at one end of the building travel the 60 feet make a U-turn travel another 60 feet to exhaust. I think I would put the slope towards the exhaust side with and actually drain into the buildings stack.
I'm making it 120 feet believing that more surface area is better. This will also provide the opportunity to collect stale air from both ends of the building while still providing contact to transfer heat.
I would like to deal with humidity using an ERV which I believe is a spinning membrane between the fresh and stale air that exchanges moisture.
Finally I'm aware that I will need to have a negative inside air pressure to prevent moisture from getting into my structure. The question I have is it possible that the negative pressure mechanical produced by ERV/HRV could still be greater then the negative pressure of just a drafty house?
Once again thanks for this site and all it's participants.
bdgWesternMass is offline   Reply With Quote
Old 07-17-16, 04:21 PM   #490
lis0r
Default Board?
Hi,
Whats the name of the foil backed board? I've tried looking for similar, but I've only found foil faced polyisocyanuranate
Thanks!
lis0r is offline   Reply With Quote
erv, heat recovery, hrv
