Old 06-07-16, 07:50 AM   #1
LJKeenan
Default HI!
Long time lurker on these forums. I have been inspired to try to figure out how to lower my propane bill for my older home i have with my girl friend.
LJKeenan is offline   Reply With Quote
Old 06-07-16, 08:36 AM   #2
Welcome to the site.
Did you have any areas you're looking to focus on, or still looking for ideas?
Old 06-07-16, 08:41 AM   #3
LJKeenan
Well I am a Professional Insulator so atm I am focusing on getting the house insulated to the best it can be but I am thinking a heat pump would help out my already efficient propane boiler combo unit
Old 06-07-16, 08:59 AM   #4
Welcome to the madness and fun! Sounds like you have the beginnings of a journey laid out already. A well planned heat pump will definitely cost less to run than tank propane. With good sealing and insulation, the two improvements could save you more money than they cost in a few years time. Especially up north.
Be sure to research outdoor units well if you are doing an air-source heat pump. The cold climate units cost more initially, but that first sub-zero cold snap will justify the added upfront expense in comfort and utility bill. Being a pro, you probably know this already.
Good luck, please keep us updated on your project.
Old 06-07-16, 09:22 AM   #5
LJKeenan
From reading here there is a pretty good amount of information like using wax to store heat who knew!
As for the heat pump I was thinking ground source but I may go air source because of how my basement is.
Old 06-08-16, 03:22 PM   #6
moorken
Guest
Posts: n/a
Hi There, i'm new too
