Go Back   EcoRenovator > Improvements > Wind Power
Old 09-23-08, 09:04 AM   #1
Default What to power with a simple wind setup
I think wind is a majorly underused source of power. Of course I've looked into small scale residential DIY kind of stuff. A simple wind setup would be a small windmill, charge controller, small battery bank, and a power inverter if you want to use 110V. The problem I always seem to have is what can you actually power with a simple wind setup? I'm thinking things like lights (CFLs of course) and fans. These things don't take lot of power but you find yourself using a lot. Anyone have any other ideas?
Old 09-23-08, 09:35 AM   #2
groar
X-Frenchy: very
groar's Avatar
Your 1.4W LEDs
Your radio alarm, your radio
Your battery (AAA&AA) charger, your mp3 player, your cell phone
Your small fridge (the 6 beers model
Your Internet router, your wireless router
Your laptop, but only a few hours a day
Your TV decoder and TV set, sorry.
But like with simple solar systems, simple wind systems will not deliver a lot and will never pay for themselves, except if you DIY some parts and get second hands for other parts.
See my calculation for a single 24/7 20W laptop on a "simple" solar system.
I heard that where there is the most wind, a wind system generates a third of its maximum. Where I live it's a tenth so only for the wind mill it will pay for itself in 20 years. Add the charge controller, the batteries and the inverter...
What is the most expensive is the batteries. I would like to have a system that connects directly to the internal electric network to feed a part of the little 24/7 electric systems.
Denis.
  • kg saved 06/08-08/09: 1816.9+382.9 (ecodriving / 1420mi not driven) = 2199.8
    (2.66 kg/l diesel)
  • kg saved by 3kWc photo-voltaic solar panels : 187 kg/yr
    (59.1 g/kWh)
  • Long life (>100,000 years) : 2.85 g/yr (0.9 mg/kWh)
  • Short life (<300 years) : 31.7 g/yr (10.0 mg/kWh)
groar is offline   Reply With Quote
Old 09-24-08, 06:21 AM   #3
toyobug
avid DIY'r
toyobug's Avatar
I have found alot of answers on this site:
Wind FAQs
toyobug is offline   Reply With Quote
Old 09-25-08, 09:16 AM   #4
I've talked with a few guys about how to get used free/cheap deep cycle batteries. I've had recommendations to stop by semi repair shops and boat shops to see what they have as far as used batteries. This is by no means perfect, but it is definitly cheaper than new batteries!
I think if you can get a small bank of batteries, build a windmill yourself and get a descent charge controller and power inverter you should be able to make a small, but fairly inexpensive and cost effective system.
I too would LOVE to have a grid tie inverter so I could sell back power to the utility. However, I've heard that the cheapest ones are very close to $1000 (US). That would by far be the largest chunk of the entire systems price.
Old 09-25-08, 10:10 AM   #5
toyobug
avid DIY'r
toyobug's Avatar
with the grid tie you have to keep in mind the cost of using a Licensed electrician.
Old 09-28-08, 08:43 AM   #6
dremd
Need More Eco
dremd's Avatar
Send a message via AIM to dremd
Man I wish grid tie was affordable.
If you cam come up with some sort of transfer switch (charge based) that would be awesome. You could even run a fride or similar sized load.
dremd is offline   Reply With Quote
Old 09-30-08, 03:58 AM   #7
toyobug
avid DIY'r
toyobug's Avatar
DITTO!!!
I'm sure most have seen or heard of the generators that are tied into your home. Don't these use some sort of switching mechanism to allow them to come on when a power outage is detected?
I'm still learning about grid-tie systems myself but couldn't something like that be used, or at least technology along those lines?
Anyone???
Old 09-30-08, 08:39 AM   #8
SVOboy
SVOboy's Avatar
Food for thought: V10 (vawt,savonius,vertical axis,windturbine,ametek)
Old 09-30-08, 01:05 PM   #9
toyobug
avid DIY'r
toyobug's Avatar
i'm curious to know how well it works. Looks simple enough to build. Any one thinking of building one?
Old 09-30-08, 01:30 PM   #10
I'm very excited to start a wind project. I just have so much to do before doing that. Maybe next summer.
