Old 06-29-10, 04:17 PM   #1
Default Contamination under glass? (PV panels)
I've been looking at some Stain-like discolorations on my panels..
(Actually in my panels, under the glass, on the cells).
When you look close (last pic), the stains looks little like a red-brown rust color
on the silver conductors and it makes the cell surface look darkened in areas it covers.
Here's some pics.. Is this normal, for less expensive panels?
Comments please..
Old 06-30-10, 02:28 PM   #2
Default Four SPM125P panels
Here's a pic of all four panels, as seen from a distance.
Not only are there stain lines, the panels look oddly different from each other.
Brownish, instead of the light blue (as shown on Ebay & importer website).
The little 'stain' lines look a bit like water-marks from rain drips, but they
under the glass. They are bonded in permanently.
Old 08-26-10, 02:10 PM   #3
Default August 2010 update
I was out taking some pics with the new Red Rock tracker module and noticed the lines (of contamination?) appear to be getting darker.
These panels were purchased on Ebay from UL-Solar, Solar Panels at UL SOLAR, Inc Online Store
they were imported by Solar Panels
The importer has informed me "They are not suppose to be like that.", but said power levels won't be affected.
They asked me if I would like to return the panels and get new ones.
I'm a bit reluctant to ship these and chance getting shipped (undamaged) from the west coast (to the east coast).
Old 08-26-10, 04:02 PM   #4
Has a google search revealed anything about what it might be?
Old 08-29-10, 11:04 AM   #5
I'm not sure how they 'laminate' glass on top, but I'm guessing they use
something similar to a vacuum bag rig, to pull all he air out.
Maybe that process was leaky? Or maybe the adhesive used had some contaminates in it?
The stains make them kinda look homemade to me..
Old 10-15-10, 09:41 AM   #6
With the cooler weather, I'm starting to see about 95% of the rated output of DC watts.
That's into a fixed 10 ohm load. So, I can't help but think MPPT might help the array achieve even more power out,
especially under less than idea conditions.
Overall, I'm pretty happy to see this amount of power delivered into a simple 10 ohm load.
So, I want to take a philosophical view of the ugly panels. I'm going to look at these
stain lines as a theft deterrent. Since anyone looking at them is going to
think, "What's that? Are these defective?"..
Hey, it might work!!
Old 10-15-10, 01:04 PM   #7
TimJFowler
TimJFowler's Avatar
Are there weep holes or any sort of venting for the panels? It could be moisture in the panels that needs to escape.
Old 10-15-10, 02:44 PM   #8
Don't think so. They cook these things in a vacuum oven.
So, there shouldn't be any gaps inside the sheet.
Here's a vid showing the manual version of the assembly.
I can't believe the narrator can't say 'solder' or 'volt' meter..
Maybe it's just my ears.?.
I wonder if someone just forgot to clean off the solder flux or wash their hands?
Old 11-29-10, 04:55 AM   #9
smithmiller6
I would be worried about the power producing capacity with those stains on..
smithmiller6 is offline   Reply With Quote
Old 11-29-10, 07:14 AM   #10
When it's cold and sunny, power is not a problem. I'm amazed how well these work.
They can hit well over 500w..
http://ecorenovator.org/forum/solar-....html#post9767
