12-08-13, 01:35 PM | #1611 | |
12-08-13, 03:35 PM | #1612 | |
It Rarely gets down to freezing here. The past few days it was in the 80s. Then the cold wave hit . Dropped down to the 30s. Had ac on Friday night. Last night. The heater was on. And had to wrap the jet pump scared it would freeze. But this is once and a blue moon weather for us . |
12-08-13, 03:55 PM | #1613 | |
What kind of pump did you decide on. I seen you had went with a small aquarium pump for one ya test but that flow was to small. I think that an open loop geothermal takes 1.5 to 2gpm per ton. I havent given much thought on the water circulation. On the groutin The main purpose for the grout is contact with the pipe so they can transfer the heat to the soil.If their formation is hard (clay,rock, limestone ,etc) forms like that they will benifit from grout. If it is sandy . They dont . The sand will cave back in on the loops only the top to the water table needs to be bentonited,grouted or cemented. |
12-08-13, 04:01 PM | #1614 | |
Their 250ft deep. Sand collaspes around it The top part your required to bentonite . Protect the water from the rain and etc. Weve don some i believe they were 420ft deepest ones weve done here. They was for govt buildings though. There loop field was Huge compaired to all of ours |
12-08-13, 04:06 PM | #1615 | |
12-08-13, 05:07 PM | #1616 |
I especially love this one:
If a teenager can do it, you can do it. Water is an awesome secondary refrigerant. EDIT: Here are the original threads: http://www.xtremesystems.org/forums/...memade-chiller http://forums.extremeoverclocking.co...hlight=chiller Last edited by jeff5may; 01-30-14 at 07:29 AM.. Reason: added links |
12-09-13, 01:08 AM | #1617 | |
I think that I can calculate your pump size for you. I need to know:
12-09-13, 12:10 PM | #1618 | |
So what's with a photo with no explanation and no link? You trying to keep this thing secret? -AC
12-09-13, 12:22 PM | #1619 |
It is 3 holes dug 250 deep. Loops set right close to 250 may be 248 or 249. But lets round it 250 still 3 ton thats for the whole house well pump house and the shop. (never had money for unit or ductwork yet) And we sized it for the additions i will be doin also
Bein their just sittin taped waitin to be hooked up. I will just use 1 hole at the 250ft. Thats 1 ton. I understand that a ton will do 600-700sq ft But That should be plenty to heat and cool the 450sq ft . 8ft celins. Unless you think thats overkill on the depth. I do know how to dig em my self by hand around 40 to 60ft. Horzontal i will run 10ft lenght to that closest hole still use the 3/4. so all togather 530ft of 3/4 pipe |
12-09-13, 12:26 PM | #1620 |
O and im tryin to get 6000btu right now out of that 240ft to a ton here we dig em 250 to compensate it floatin back up when you remove the hole loader . But when i get th other unit i will try pull the whole ton out of that hole.
Tags |
