11-02-14, 10:12 PM | #1 |
Automotive AC dehumidifier Cross-breed heat pump
I have non functioning AC in my car that I want to remove , I also have a need for some free or recycled components for a dehumidifier based heat pump.
I will be removing the car's large near 3 ft x 2 ft ac condenser that is mounted in front of the car radiator, I think it will work well as the condenser in the heat pump build , do to its large area. The car also has a evaporator mounted under the dash that I can salvage if need be, although it appears smallish in scale compared to the condenser , it's thicker and should be ? plenty large for the dehumidifiers compressor I deduce. I will pull the parts off the car in next couple of days and see what I have to work with. Any advice would be great as you may foresee some issues or methods I might be interested in. I will add pictures when the parts come off. |
