12-10-13, 08:40 AM | #11 |
This one will use less e power and put out more heat. I am not sure this is in your budget. But it will be cheaper in the first year if you use it very much.
Gree 9,000 BTU 27 SEER Terra Ductless Heat Pump Air Conditioner System https://www.acwholesalers.com/Gree-A...rail=1004:Gree I have one just like it is keeping me warm right not using about 400 watts right now. You can also buy cheaper mini splits but not to much more efficient. Last edited by pinballlooking; 12-10-13 at 08:57 AM.. |
12-17-13, 10:17 PM | #12 |
Yes heat pumps are the best option to heat. It works efficiently and effectively, heat pumps are the best choice and affordable too. It saves money and energy.
The Following User Says Thank You to Ezrio315 For This Useful Post: | RichySuth (12-25-13) |
12-20-13, 12:09 AM | #13 |
A mini split with 2 indoor units would be exceptionally effective.
I should be a salesman |
